Lighting Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jason85, Nov 7, 2014.
  1. Nov 7, 2014 at 8:50 AM
    Jason85
    Jason85 [OP] Member
    GA
    TRD Xtra cab
    So I'm having a problem, every time I mash the brake pedal my running lights come on (interior and exterior). Also sometimes my cruise control won't work. The cruise light will come on but the cruise won't do anything. I have also noticed whenever the cruise isn't working the torque converter clutch will not lock up. Just stated this a couple weeks ago. I have replace the Brake Light Switch but nothing changed.
  2. Nov 7, 2014 at 9:54 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    check you battery terminal connections, disconnect clean and retighten them.
    this makes sure you have good electrical connections. corroded battery terminals cause cause a lot of weird stuff
    if that doesn't solve it then disconnect you trailer light wiring module, they can short out and cause all sorts of weird lighting issues
  3. Nov 7, 2014 at 10:52 AM
    Crock112
    Crock112 Well-Known Member
    Crock
    New England
    '04 2.7l SR5 4x4 xtracab
    This. I was having really weird electrical issues where my turn signals wouldn't work when I stepped on the brake, or turned my headlights on. There were a few other weird quirks too but I can't remember exactly what was affected. I traced a bunch of wires looking for a bad ground somewhere, came to the TW forums and saw someone else recommend disconnecting the trailer light wiring module and that fixed it.
  4. Nov 7, 2014 at 11:24 AM
    keakar
    karl
    louisiana
    if it is the trailer wiring module then don't buy a new one just use my mod to permanently fix it forever http://www.tacomaworld.com/forum/lighting/347862-diy-easy-10-trailer-lights-plugin-fix.html
    the module goes spastic because it sends power through a transistor that isn't needed and this transistor is what always goes bad and causes all your problems. I think they just use it so it will go bad after a year or so and make you buy another one
  5. Nov 9, 2014 at 3:38 PM
    Crock112
    Crock
    New England
  6. Nov 10, 2014 at 1:28 PM
    Jason85
    Jason85 [OP] Member
    GA
    TRD Xtra cab
    Thanks for the suggestions but it turned out to be a faulty Brake/Tail light bulb. Looking at the bulb you couldn't tell it was bad. Both filaments were intact and working but as soon as I replaced the bulb the problems disappeared.
