Lighting Question.... for all of them
Discussion in 'Lighting' started by bacollier90, Oct 1, 2015.
  1. Oct 1, 2015 at 11:38 AM
    bacollier90
    bacollier90 [OP] Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Lots of lighting questions....
    First.... Front: I am looking to do the BLHM when I change my chrome grill next week. Should I wait and do retrofits at the same time? I like the look of the retrofits but the cost seems a bit extreme. How much should I look to spend on that and can someone direct me to a good how-to?
    Rear: I cracked my drivers side tail light (slightly). So far no moisture problem but, eventually Ill want to upgrade to leds of some sort. Opinions here? I know front lights it is good to stay stock housings because of the direction but, rear lights should be fine to go aftermarket. Right?
    3rd Brake light: I see all of these LED bed light kits but, my 93 ranger had a switch that turned on a white light incorporated in the 3rd brake light. Much higher and provided quite a bit of light. Has anyone done this for a tacoma? I assume the wiring might be a PITA.
