Lighting recommendations?
Discussion in 'Lighting' started by HomerTaco, Sep 5, 2014.
  1. Sep 5, 2014 at 8:28 PM
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Looking for a stout replacement to the stock fog lights. What's a good LED replacement that won't set me back a ton? I'd like to use the existing stock wiring & switch as well. I'd like a round light that will fit in the openings on my Elite plate bumper.
    Thoughts?
  2. Sep 6, 2014 at 3:35 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    You could just replace the bulbs with Lifetime LEDs or replace the whole light with the Morimoto xB fog lights.
  3. Sep 6, 2014 at 3:41 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    What I was thinking too. But they are probly gonna be too small for that hole. Could always fab a little bracket up. Or fill it in with sheet metal or mesh or something.
    Homer what's the diameter?
  4. Sep 6, 2014 at 3:47 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    There was a guy somewhere on here that replaced the whole fog light assembly with a big LED lamp that was really bright. do a little searching and you'll probably find it.
  5. Sep 6, 2014 at 3:50 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Just got stockers back in today... whatever you do avoid PIA :laugh:
    I like my fogs mellow yellow but you can always put in stronger bulbs and better wiring.
    ATO bracket worked great on mine.
  6. Sep 6, 2014 at 4:00 PM
    NightProwler
    Harlan
    Maricopa, Az
    I was just poking around on eBay.. found a few kinda cool looking led projector fogs. Basically similar to the morimoto but with a deeper reflector inside. Cheap China crap but about all I know of off hand. They might be ok.
    http://pages.ebay.com/motors/link/?nav=item.view&id=131288895218&alt=web
    http://pages.ebay.com/motors/link/?nav=item.view&id=281432765895&alt=web
    Then there's these but they arent really fogs. More like spot lights from vision x
    http://www.visionxusa.com/LED-LED_P.../index.html?osCsid=fiv08h6h2u631mk42tnftn1834
  7. Sep 6, 2014 at 4:09 PM
    NightProwler
    Harlan
    Maricopa, Az
