lighting!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Jan 20, 2010.
  1. Jan 20, 2010 at 10:37 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  2. Jan 21, 2010 at 11:23 AM
    kinkrider101
    santa barbara
    wheels and tires
  3. Sep 21, 2011 at 4:28 PM
    warthog
    warthog Beach Rider
    mitchell
    brazoria county texas
    96 tacoma v6 5 speed 4x4
    11in lift, rock crawl bumpers and body rails, newer model trd rear axle with 488 gears, kc lights on the bumper and halogen reverse lights under bed, sitting on 20in MOTO metal tires warped in 37in 13-50 allterrains, a cb radio, a pa system, air horn
    Simple all u have to do is rrun a wire off the positive side of ur battery to the toggle then another wire out the other side of the toggle to the first light positive, then connect the first lights negative to the second lights positive. Then the second lights negative to the third lights positive. Then connect the third light back around to the battery, or git a self tapping screw and put it in a clean metal surface with the fire twisted around the screw. Make sure u put a 25 volt fuse in the wire just after the battery or before the switch somewhere convent that will make changing it easy. 12 in. after the battery will work best. And if the toggle switch is backwards. On is off off is on. Then just reverse the way u put the wires on the back of it....simple huh
  4. Sep 21, 2011 at 4:32 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The link was real slow to open for me... Probably best if you just post the catalog photos in your post?
    Says they are 55 watt halogen... which is pretty dim, like your headlights. Suggest changing to 100 watt halogen or convert to 35 watt HID (5000ºK) for even more light!
