Lighting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2wdSR52022, Mar 21, 2024.
  1. Mar 21, 2024 at 5:44 PM
    2wdSR52022
    2wdSR52022 [OP] Well-Known Member
    Jc
    Expensive SR5
    Good afternoon. I did search!!! And there is soo much information on the headlight upgrades. Si if someone changed their bulbs to something plug and play please let me know what to buy. I’m not really mechanically savvy. I need to update the headlights on my sr5.
    please. You don’t have to tell me there are a bunch of threads on this. I know and I’ve read. but I’m hoping to get a simple solution
  2. Mar 21, 2024 at 6:04 PM
    mdp5094
    mdp5094 Well-Known Member
    Pennsylvania
    2020 Super White Tacoma SX Access Cab
    Mudflaps, KC G4 fogs, TRD grill, Black Letter inserts.
    Thanks for posting this. I fully agree and have been trying to dig through this damn forum to find my information. THERE ARE TOOO many debates and threads.I am in the market for a set of LED replacement foglight bulbs myself. I just wanted to see a thread with a recommendation of simply replacing the LED bulbs in my TRD off road and mabey include a picture. I feel like every Japanese car, truck or SUV deserves yellow or amber fogs.
    Please and thank you for any suggestions.
    PS. not trying to hi-jack your thread. But figured I would get an answer here regardless. If I dont I will do what you did and delete this in a few days if no replies.
  3. Mar 21, 2024 at 6:07 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Phillips H9s High and low, for low ether remove the green cover in the harness side of the connector or get H11 to H9 adaptors
    vicali, rolled93slc, usmc2msu and 2 others like this.
  4. Mar 21, 2024 at 6:16 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    the problem is LEDs emitter faces are about 30% wider than the with of the filament winding of an incandescent lamp and the high output LEDs are 6500K
    you will never get a good bubl swap
    just get some Diode Dynamic LED fogs in Selective Yellow and call it good you will probably want the SS Max given your snow climate
    soundman98 likes this.
  5. Mar 21, 2024 at 6:29 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I have ran HIDs LEDs and Halogens. The H9 upgrade is very simple snd gives the best output for a simple upgrade. Drop in LEDs just don't work properly.
    usmc2msu, RIX TUX and musicisevil like this.
  6. Mar 21, 2024 at 6:36 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Your led fogs don’t have bulbs. It’s a sealed unit. If all you’re looking for is yellow light people have had success putting tinted film over the lenses. Lamin-x I believe it’s called.
    To upgrade you’ll need new units. Diode dynamics and Baja Designs are the two popular choices around here. If you’re going to use them in traffic you should use SAE fogs so you don’t blind other drivers
    @2wdSR52022 the sticked lighting thread is pretty much all you need, but it’s very long. H9 bulbs are what are already in your high beams and they are the top recommended upgrade for your low beams. It’s a very simple “mod”
  7. Mar 21, 2024 at 6:52 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    H9s since you just want an answer. The research has been laid out in the first post of the long thread,, but the end result is H9s.
    usmc2msu and RIX TUX like this.
  8. Mar 21, 2024 at 7:03 PM
    PLavee
    PLavee Active Member
    Philip
    ‘20 TRD OR DCSB Red
    I did and am very happy - info came from this web site: https://www.bulbfacts.com/.(look at "Aftermarket LEDs" and select "Chart". They actually test bulbs and post results.
    Based on their recommendation: for low beams, which are projector type, I have Hikari 2023 Future H8/9/11 (Amazon sells them).
    For high beams, which are reflector type, I have DDM Tuning 65w Saber ProX.
    A bit more details - in the past LED's used to have a thick heat sink (which the LED chip mis mounted on), and the result was really poor beam shape - in those days, upgrading to LED was a worse choice than a high quality Halogen. Newest LED's, like the premium options above, have a very thin heat sink (and use more exotic materials for heat conductivity) - the result is a fantastic beam shape that is even better than my Lexus tri-beam LEDs. I do recommend.
    Hotwheels85 likes this.
  9. Mar 21, 2024 at 7:24 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    I’m very happy with these. Price is right too. I have them in both the highs and lows.
    https://a.co/d/gGdDzFl
  10. Mar 21, 2024 at 7:27 PM
    Veet-88
    Same set I tried. Appears brighter but the actual usable light at distance is trash in comparison to the H9 upgrade. No actual hot spot. I even went as far as to try the h9 led in the low beam.
  11. Mar 21, 2024 at 8:16 PM
    lavrishevo
    2023 Trail Edition
    I don’t experience this at all, much better vs the halogen lamps that came with the vehicle.
  12. Mar 22, 2024 at 3:12 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have been using Didoe Dynamics SL1 high and low beams for about 5 years with no issues whatsoever. Nice cut off lines, wider beam and it works well for me. It puts a nice beam as it a huge improvement over stock and I tried the GE Mega halogens and the SL1s are tome better. I'm lifted and never been flashed, I thought about upgrading to the OEM lights, but I rarely drive at night and if I do it's in my old 99 4Runner or the Wife's new 4Runner.
  13. Mar 22, 2024 at 4:06 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    A buddy at work got Auxito leds and now like 10 of us run them here.
    He loves his and has been running them for like 3 yrs no issues.
    I’ve used them also yellow fogs and now headlights absolutely happy with them.
    Fans are quiet light is awesome and they last. I believe they have a 2 yr warranty on their stuff also.
    Later when it gets dark I’ll snap a picture and add it here.
    usmc2msu likes this.
  14. Mar 22, 2024 at 6:05 AM
    mdp5094
    Pennsylvania
    Ok, thanks for the responses and for the suggestions. I just do not understand, I have a GR corolla as well as the tacoma. And I under stand they are different cars etc. But recently got a set of yellow/amber LED foglight bulbs and just simply swapped them out for the OEM ones for the new ones.
    I looked at my window sticker on my taco and it said I got the upgraded LED foglights and headlights, so I made the assumption that I could just do the same thing with the LED bulbs.
    Bottom line, it seems like the LAMIN-X film would be my best bet, rather then upgrading the entire bulb which according to the post above its " a sealed unit"?
    Thanks again, this forum has just gotten sooo big (IMO) that its hard to find a definitive answer.
    I don't really care about beam specs, and what not. Going from an SR SX which I had before with the amber DRL's and I had some Baja amber fogs, added to the truck. I assumed it would be an easy swap out with bulbs on my new TRD OFF ROAD. But apparently its alot more complicated accordings to posts.
    musicisevil likes this.
  15. Mar 22, 2024 at 7:01 AM
    YotaHead858
    YotaHead858 Well-Known Member
    San Diego, CA
    2023 TRD OR
    King Shocks Camburg UCA's
    Yes, if you have the upgraded LED head lights and fog lights, both are sealed units.
    If you go with yellow film over your stock LED fog lights, you'll slightly lose light output. If you're looking to upgrade the fog light go for Baja Designs or Diode Dynamics (Elite Series, SS3 Sport/ Pro, etc.)
    musicisevil and mdp5094[QUOTED] like this.
  16. Mar 22, 2024 at 9:14 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @2wdSR52022,
    If you're considering enhancing your headlights for better visibility, while we don't provide headlight bulbs, we do have alternative lighting solutions that could be beneficial. Specifically, we offer a convenient direct plug-and-play fog pocket kit tailored for the Tacoma. This product will be available in both our sports line and an SAE variant. If you're a frequent road traveler seeking an upgrade, our SAE option might just be what you're looking for. Below, I've included some additional information for your reference. Should you have any inquiries or wish to receive a customized quote, don't hesitate to reach out via email at bill@bajadesigns.com.
    Toyota Squadron-R SAE Fog Pocket Light Kit - Toyota 2010-24 4Runner; 2012-23 Tacoma; 2014-21 Tundra
    Toyota Squadron-R Sport Fog Pocket Light Kit - Toyota 2010-24 4Runner; 2012-23 Tacoma; 2014-21 Tundra
    Best,
    Bill
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.com Phone: (760)560-2252
  17. Mar 22, 2024 at 9:19 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Those actually decrease output and seeing distance when used in a halogen housing
  18. Mar 22, 2024 at 10:23 AM
    musicisevil
    Alaska
    2019 TRD Sport
    “Not to my eyes
    They are way brighter
    I never get flashed”
    - People who use led bulbs when presented with repeatable test results and facts about halogen assembly design
  19. Mar 22, 2024 at 10:32 AM
    3rd gen AC SR5 4x4
    Thing is, no one is above the laws of thermodynamics
    soundman98 and Chasespeed like this.
  20. Mar 22, 2024 at 11:02 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    -also people who drive around under streetlights in a city 24/7..
