Lightly rolled my 96 Tacoma. Now it won't start?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikieSwartz, Jan 19, 2020.
  1. Jan 19, 2020 at 2:03 PM
    MikieSwartz
    MikieSwartz [OP] 5.7L iForce V8 Tacoma : YouTube.com/WhipBash
    Carlisle PA
    Rolled 05 Tacoma 4x4 crew cab "Tacundra" + Rolled 96 Tacoma 4x4 Budget Build
    05 Tacoma: 37" Tires, Method bead-locks, Long Travel, King shocks, Custom fabrication, currently swapping in a 5.7L 3URFE Tundra V8 ! 96 Tacoma: Budget Build Lots of DIY !
    I've had this truck for about 10 years now. Off road only. Was rolled hard on-road before I bought it and turned it into a trail truck. Now I just sat it on it's side for my first time. The truck shut itself off before I could even grab the key. It sat overnight until I got a tractor to come pull it back onto it's wheels. No significant fluid loss. Now it will crank but not start.
    I removed the circuit opening relay and banged it around - hoping maybe it had some sort of floating ball that would need reset. That didn't work. So I bypassed it by connecting the ignition power directly to the fuel pump. Now I can clearly hear the pump run, but still no start. I checked the wiring diagrams and I don't see anything else that would prevent it from starting.
    Fuel gauge reads 1/2 tank and has always worked. I also tried spraying brake cleaner in while cranking but still didn't start. Have not checked for spark yet, but I gotta assume it's not sparking. Honestly, haven't tried much cause I'm frustrated and it's cold out here in PA right now! Maybe TacomaWorld can help?
    Here is a video of the aftermath. https://youtu.be/ge_LmHbKpyE
    Oh and also on my YouTube channel, building a 2nd gen with a 5.7L Tundra V8 engine. There's a thread for that on here too.
  2. Jan 19, 2020 at 2:04 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    "Lightly rolled"? Is that like, "sorta pregnant"? :rofl:
    wolfgang123, jenk, VirusCage and 10 others like this.
  3. Jan 19, 2020 at 2:05 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Hey Mike!
    MikieSwartz[OP] likes this.
  4. Jan 19, 2020 at 2:08 PM
    PennSilverTaco
    Charlie
    I've got pictures of this truck from the Truck Nationals last year! I thought it was a 1998...?
    [​IMG] [​IMG] [​IMG]
  5. Jan 19, 2020 at 2:47 PM
    MikieSwartz
    Carlisle PA
    LOL... Let me clarify... The truck is BEAT. But this particular roll was basically sitting still. I was backing up and the left front tire dropped in a hole just as the right front tire was peaking on a steep incline. So it just teetered onto it's side as nicely as you could imagine. Not a violent crash or anything.
    PennSilverTaco likes this.
  6. Jan 19, 2020 at 2:51 PM
    MikieSwartz
    Carlisle PA
    pennsilvertaco Thanks dude! There is is looking all proud and beat up. LOL
    Still like my favorite truck I've ever had.
  7. Jan 19, 2020 at 2:53 PM
    PennSilverTaco
    Charlie
    Do you still have the red X-Runner?
  8. Jan 19, 2020 at 3:02 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    That custom short bed is killer. I'd take this over a new jeep anyday. Nice truck.
  9. Jan 19, 2020 at 3:08 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Tempura truck. Lightly battered.
  10. Jan 19, 2020 at 3:47 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I’m assuming you pulled and cleaned the plugs and cranked it without the plugs in, right?
    landphil likes this.
  11. Jan 19, 2020 at 4:06 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You know what they say about assuming, I assume?? :D
    First place I’d look.
  12. Jan 19, 2020 at 4:08 PM
    ToyotaDriver
    Idaho
    My gal insists that I’m an ass, so I’m not sure what harm assuming might do.
    landphil[QUOTED] likes this.
  13. Jan 19, 2020 at 4:11 PM
    ToyotaDriver
    Idaho
    If you didn’t pull the plugs before you cranked it, you might want to do it and check compressions to make sure you didn’t bend something.
  14. Jan 19, 2020 at 4:21 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    A compression test might be going too far in this case. I’m going with:
    Remove plugs.
    Spray plugs with brake clean to get the oil off.
    Crank the engine with no plugs ‘till oil stops misting out.
    Squirt some brake clean into the cylinders, and give it another crank.
    Install the plugs, start it up.
    Ignore any knocking, smoking, or funny noises. It’s normal according to Toyota.
    BeLance89 likes this.
  15. Jan 19, 2020 at 4:48 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Hello Mike,
    You truly have an amazing Tacoma. I am sorry I don't have input as far as helping you get it started other than what has already been suggested.
    I am just curious. How many miles are on it?
    You have a question about what model year it is. Just check the production tag in the driver's door.
    Take care,
    Paul
  16. Jan 19, 2020 at 5:50 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    if you left it sit overnight chances are it's oil soaked everywhere and the plugs are coated. like others have said, pull plugs, and you may even want to let it sit another day before trying to crank it just so everything has a chance to drain back to the pan.
  17. Jan 19, 2020 at 11:35 PM
    MikieSwartz
    Carlisle PA
    Thanks for all the replies and the compliments on the truck. :)
    It's been upright for about 2 weeks now. I never pulled the plugs to clear out oil in the cylinders, but that would be easy enough to do. I'll check for spark too. Then I'll check back in.
    cruiserguy likes this.
  18. Jan 20, 2020 at 5:25 PM
    MikieSwartz
    Carlisle PA
    So honestly, I figured out what was wrong late this afternoon. However, I was in the middle of editing this video at the time. LOL So this video gets posted first... Still curious if anyone can figure out the problem though. TBH, my own mind was kinda blown. https://youtu.be/hJ1mEw7fM0o
  19. Jan 21, 2020 at 5:09 PM
    MikieSwartz
    Carlisle PA
    crazytacoman and PennSilverTaco like this.
  20. Jan 21, 2020 at 5:20 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    :popcorn:
    Watching this was like deja vu - watching the Hilux kill on Top Gear :thumbsup:
