lights behind elusive elements grill
Discussion in 'Lighting' started by rhowell, Sep 29, 2011.
  1. Sep 29, 2011 at 3:42 PM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
  2. Sep 29, 2011 at 5:42 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    don't buy this, if you want to install HID on it.
  3. Sep 29, 2011 at 5:47 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    what kind of grill do you have?
  4. Sep 29, 2011 at 6:06 PM
    timsxr
    timsxr Well-Known Member
    portland
    they might sit a bit low in the grill
  5. Sep 29, 2011 at 6:15 PM
    timsxr
    portland
    looks like they will sit more like this
  6. Sep 29, 2011 at 11:15 PM
    rhowell
    Robert
    Canada
    Thanks,
    They look sweet but are sitting low so I am going to make a custom connection to your light bar that will raise them about 1". It will help balance them a bit.
  7. Sep 30, 2011 at 8:08 AM
    rhowell
    Robert
    Canada
    Ok,
    I got both the grills installed last night and the light bar. Have to raise lights to complete the job and I also had to relocate the horns which for some reason no longer work!!!!!!! For those of you that have not done this mod yet I would recommend a dremmel for the cutting out of the grill. At first I could not find mine so I was resorting to other methods (not going to say way to save face), but it did not go well...........................until I found my dremmel.
