Lights behind Grillcraft- Help needed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by headhunter247, Jan 11, 2009.
  1. Jan 11, 2009 at 6:15 AM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    So spent the afternoon yesterday installing Hella 500FFs behind the Grillcraft MX. It looks great, but after all of the work the lights shake badly while driving. I pretty much installed just like others on here.
    While driving my lights bounce very bad. I can see it, and can imagine that the oncoming traffic can notice as well.
    Does anyone have any thoughts? They hang from the top of the old grill housing, just like I have seen everyone else do.
    I need to stop this bouncing, as it is very bad.
  2. Jan 11, 2009 at 7:00 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Pictures of your setup will help. Maybe there's something that might have been missed.
  3. Jan 11, 2009 at 7:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can get some flat sheet metal brackets at Home Depot. Use them to add some stability to the lights. I had to come up with some creative mounts when I installed lights in the bumper of my 2000 Tacoma, and these brackets helped.
  4. Jan 11, 2009 at 7:22 AM
    headhunter247
    St. Louis, MO area
    Here are some pics. I thought about the flat bar. I know that if I reinforce the grill shroud between the bolts, that could make it stronger, but the big thing is them shaking back and forth... Thoughts?
  5. Jan 11, 2009 at 5:32 PM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
    Looks like you mounted them directly to the plastic schroud. You will need to beef it up with aluminum (strong enough but light enough). I just did the grill yesterday and ordered Hella Rallye 1000 Black Magic lights today. I have time to find what I need to strengthen it up. A few guys have pics of their set up. I noticed someone even made a brace for the sides.
  6. Jan 11, 2009 at 6:04 PM
    hsc001
    hsc001 Well-Known Member
    laurel, Maryland
    08 TRD off road lifted
    BHLM, 3" toytec coilovers, blacked out billet grille, hella 500's behind grille, volant CAI, Dual flowmasters 40's, HID, DTLT
    what i did to help with the bouncing was i mounted the lights on the two top grille support.
  7. Jan 12, 2009 at 6:11 PM
    headhunter247
    St. Louis, MO area
    ok...I had saw that as well..thats what Im thinking that I will do...because I cant sleep until its perfect...and it looks awesome!
  8. Jan 25, 2009 at 9:43 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Any luck with the fix? I am getting ready to do the same thing.
  9. Jan 25, 2009 at 1:06 PM
    headhunter247
    St. Louis, MO area
    I havent had the chance to fix it yet, but have come up with a few solutions.
    1. Reinforce the grill shroud with 1/2" steel plate. On the top and the bottom of the shroud, between the fogs, and the top of the plastic shroud, then on top of it as well. Then if that doesnt make it sturdy enough, run the 1/2" plates from the subframe down to the top of the fog bolts as well (I did mount from the top vs. bottom).
    2. or plan B, if the first doesnt work, mount the fogs through the supports that hold on the grill (the parts that you have to take the bolts out of to get the grill off.
    Let me know as well if you have any other ideas, or use of of these. It really bothers me to not have this fixed yet.
  10. Jan 25, 2009 at 1:31 PM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    i used aluminum from lowes to mount them on and they barely shake
  11. Jan 25, 2009 at 1:51 PM
    headhunter247
    St. Louis, MO area
    can you provide further info? if there is an easy way, i would love to know it...
  12. Jan 26, 2009 at 1:10 PM
    tooblutacoma06
    tooblutacoma06 Member
    Kellon
    Houston
  13. Jan 26, 2009 at 1:31 PM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    your going to need .25/.50 inch mending plates(they are pre-drilled) across the top as well as some lateral support, I don't know how they have not already cracked or broken that thin plastic you mounted them direcly to- I would not wait to fix this
  14. Jan 26, 2009 at 2:52 PM
    jward2331
    Fleming Island, Fl
    I am curious, what are "mending plates" that are predrilled?
  15. Jan 26, 2009 at 5:15 PM
    headhunter247
    St. Louis, MO area
    yea, ive heard of these before as well, but didnt know what they look like...is this something that you can get at lowes?
  16. Jan 27, 2009 at 6:45 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Don't have your type of grill but here is the set up I did, less than $20 for the alum, no movement at all.
  17. Jan 27, 2009 at 6:46 AM
    Delmarva
    Tucson, AZ
    That looks like sex... :thumbsup:
  18. Jan 27, 2009 at 6:50 AM
    longbow
    Bill
    Indiana
    Here is another shot with out the lights on, I also relocated the horns. Still need to paint the back area black.
    Horn relocate, if your interested.
  19. Jan 27, 2009 at 6:58 AM
    Delmarva
    Tucson, AZ
    LB, I almost did that HR mod with my Satoshi, but just relocated them down further behind the valance...
    But if I didn't have the hardware available, I would have done what you did... :D
  20. Jan 27, 2009 at 7:06 AM
    longbow
    Bill
    Indiana
    Matter of fact the screws are off the Tundra I had. For some reason I have a bunch of screws of all sizes that are "stock" ???
