Lights flashing, loud idle, various other issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reneelamay, Sep 30, 2019.
  1. Sep 30, 2019 at 2:37 PM
    reneelamay
    reneelamay [OP] Member
    Renee
    2013 Toyota Tacoma pickup 4x4
    Hello, I am new member to the forum, Renee LaMay. I have a 2013 Toyota Tacoma that has been running great until recently. On August 17, 2019, while at a drive through fast food restaurant, I heard a hissing sound and saw what appeared to be steam coming from under carriage of truck. Noticeable enough to get me out of the truck to look at it. I did not see anything to be concerned with, so went about business as usual. I have heard this noise sporadically since then and noticed the A/C is not properly working. I decided to park the truck until I could take it in for a diagnosis. Well, yesterday, I went to start the truck after being garaged for 3 weeks. The truck stalled starting and then went "haywire"....instrument panel lights flashing, interior lights flashing, idle was loud, wipers wiping - all at once. I turned the truck off and when I tried to start it up again, the truck would not start. So, I charged the battery and was able to get the truck running again, but now the rear blinkers are not working and the stereo will not come on at all. Any recommendations? I just paid my baby off 6 months ago.
  2. Sep 30, 2019 at 2:39 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
  3. Sep 30, 2019 at 2:40 PM
    reneelamay
    Renee
  4. Sep 30, 2019 at 2:47 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    Wish I could help, but that is way over my head
  5. Sep 30, 2019 at 2:49 PM
    reneelamay
    Renee
  6. Sep 30, 2019 at 2:59 PM
    marshall765
    marshall765 Well-Known Member
    Shreveport Louisiana
    13 DCSB TRD Offroad 4x4
    Sounds like you need a priest.
  7. Sep 30, 2019 at 2:59 PM
    Muddinfun
    Muddinfun Well-Known Member
    Your symptoms are all over the board.
    Hissing-"steam"= Coolant leak or AC refrigerant leak
    "haywire" lights flashing= low voltage, possible alternator failure
    loud idle=?
    No start=possible alternator failure or corroded cables
    Rear turn signals and radio not working=Possible blown fuses from futzing around
  8. Sep 30, 2019 at 3:06 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  9. Sep 30, 2019 at 3:13 PM
    reneelamay
    Renee
    Thank you....I checked fuses and the one for radio keeps "popping" upon starting after being replaced....corroded cables, yes, they were, but it had only been parked for 3 weeks....why so much in three weeks? They are brass posts. This truck is usually parked.....
    irayfz6 likes this.
  10. Sep 30, 2019 at 3:14 PM
    reneelamay
    Renee
    Yes, sounds like I need a priest
    irayfz6 and BillsSR5 like this.
  11. Sep 30, 2019 at 3:15 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Coolant and refrigerant is corrosive. These issues may all be related
  12. Sep 30, 2019 at 3:15 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I would take it to an mechanic to be honest theres a lot going on with the truck
    irayfz6 and reneelamay[OP] like this.
  13. Sep 30, 2019 at 3:18 PM
    marshall765
    Wonder what the root cause is? Sounds like you several problems but it all started from one issue maybe? The truck never overheated right? Serp belt is still there?
    irayfz6 likes this.
  14. Sep 30, 2019 at 3:18 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Mice ? :annoyed:
    Hopefully not. Welcome to the forum. Sorry it’s on a shitty note.
  15. Sep 30, 2019 at 3:25 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I like the serpentine belt idea. If it's gone, it could cause overheating, no AC, and weird electrical issues as your truck slowly drains the battery.
    irayfz6 and BassAckwards like this.
  16. Sep 30, 2019 at 3:31 PM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    Battery voltage was possibly too low when you started it, I had a similar thing happen on a Toyota Camry many years ago. Check fuses for blinkers and stereo.
    Welcome and good luck!
  17. Sep 30, 2019 at 3:44 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
    irayfz6 and Taco critter like this.
  18. Sep 30, 2019 at 8:31 PM
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Jesus now I need to know if op was just cruising around with no serpentine belt. Wouldnt you get idiot lights without it? At least battery?
  19. Sep 30, 2019 at 8:37 PM
    andrew61987
    Not exactly sure what you'd get without it. The few times in my life I've started an engine without a belt I sure as shit wasn't wasting any time looking at the dash lights. But I have to think that driving without water circulation is gonna toast that long block rather soon. Let's hope OPs problem is something less serious.
  20. Oct 1, 2019 at 1:49 AM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Welcome!
    irayfz6 likes this.
