Lights for my 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by summerboy1958, Dec 7, 2009.
  1. Dec 7, 2009 at 4:12 PM
    summerboy1958
    summerboy1958 [OP] Well-Known Member
    Bruce
    Newark, De
    01 SR5 4WD, Radiant Red
    Hidden Hitch Trailer Hitch, Timbren Shock Assist System, Billy 5100's all around, Deck plate mod, AFE Pro Dry air filter, Amsoil 85W-90 Severe Gear Oil in the transmission/differentials/transfer case.
    I posted this thread in the lighting section, but thought I'd drop it here also, as I am looking for input from 1st Gen owners.
    I've noticed that the headlights on my "new" 2001 seem kinda dim. Hard to see under normal conditions and forget it when it rains. The headlight lenses are fogged a little and I bought a Turtle Wax lens cleaner kit to try 1st (I really bought it for my kids cars, but thought I'd try it also). I would expect that would help some, but I'm guessing not enough. I don't know whether I can just get better "bulbs" or need to try something else.
    Also, I'd like to install some fog lights and like the "built in" look. What are my options? I've got a 2001 SR5 4X4 Ext cab. If I can't get a built in set, Whats my next best option?
    Thanks!!
  2. Dec 7, 2009 at 4:16 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    yeah you could try the turtle wax stuff, but if they are just fogged a little bit then it sounds like you just need new bulbs. i got ones from napa that are the wagner ultra whites, and wow what a world of difference.
  3. Dec 7, 2009 at 4:19 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    Hi,
    I have an old 1st gen like you. noticed my headlamps where dim. I went to wal-mart and got the the sylvania super replacement. it says it's 15% better than the old light. Just buying new lamps will make your lights brighter. The old headlamps are dim. lost thier brightness. it's a cheap upgrade. 10 bucks a piece!
    OH wait, you have a 96 ? they might be different. my bulbs come within the headlamp housing.
    Not sure about fogs yet. still studying up on that one.
  4. Dec 7, 2009 at 4:19 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    I hid a set each of Hella driving and fog lights under my bumper. Helps out alot.
  5. Dec 7, 2009 at 4:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....there are different kinds of bulbs that you can use......some are brighter/appear to be brighter....like the sylvania silverstar, but i havent used them on my tacoma yet. some like them...some say they burn out too quickly. they did fine on a ford ranger that i had long ago.
    as for the built in look for fog lights...there is a mod where you can turn the corner lights into the blinker lights, and you can add some hellas(i'll try to find exactly which ones) in place of the bumper lights and use them as fogs.
  6. Dec 7, 2009 at 4:25 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    isn't it the hella 550's?
  7. Dec 7, 2009 at 4:25 PM
    summerboy1958
    Bruce
    Newark, De
    JDMCQ - That's a good look, do you have a thread on the install?
    tacomaman06 - That would work also. Is there athread for that?
  8. Dec 7, 2009 at 4:25 PM
    JDMcQ
  9. Dec 7, 2009 at 4:27 PM
    JDMcQ
    No, I did that a long time ago. It was pretty easy though. The bumper cover has to come off and then the actual bumper crossmember. The light brackets bolt to the crossmember using nutserts. The wiring is real simple, just follow the instructions. I will try to find the model numbers of the lights.
  10. Dec 7, 2009 at 4:29 PM
    JDMcQ
    I used Hella FF75 for the driving and Micro DE for the fog lamps. They fit perfectly.
  11. Dec 7, 2009 at 4:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  12. Dec 7, 2009 at 10:51 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    if you got $150 layin around, upgrade your stock headlight bulbs to HID...
  13. Dec 13, 2009 at 7:52 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I can tell you how to do that easy... Just go to Uhaul and get a trailer wiring plug installed. Drive around for a few months and boom, your corner lamps will come on whenever you hit a turn signal AND as an added bonus they come on whenever you hit the brakes! :mad::mad:
  14. Dec 14, 2009 at 11:38 AM
    scriber007
    scriber007 Well-Known Member
    You can get headlight restoration kits and replace your bulbs with some ultras from sylvania, or get the hellas high performance or nokya artic whites. I have used all of them the work great, PepBoys carriers them.
  15. Dec 14, 2009 at 2:56 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    Sylvania Silverstars always do me right
  16. Dec 14, 2009 at 6:45 PM
    98lowflyingtacoma
    98lowflyingtacoma Well-Known Member
    Phoenix
    1998 Tacoma Prerunner
    i really wanted to do that too but ended up getting a bull bar for $50 bucks then throwing some PIAA lights on it...
  17. Dec 15, 2009 at 4:10 PM
    jlwilsonjr
    jlwilsonjr Well-Known Member
  18. Dec 15, 2009 at 4:38 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    you can get the fog remover by a pro or get some new light housing from ebay. Also, check into aHID kit. I have them on my truck and there reallllllllly bright! i love them.
  19. Dec 15, 2009 at 6:18 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I went to the local auto part store and found some really bright, blue light bulbs, becuase mine two were faded. These new bulbs are 10 times better than my old ones...definatly get new bulbs
  20. Dec 15, 2009 at 6:36 PM
    ScottyB
    ScottyB Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    If your lenses are fogged and you can polish them off to make them nice and shiny again the plastic is probably oxidizing. It's probably just going to happen again in a couple months unless you keep a nice coat of wax on there. I know there's a place here that will polish/buff out old headlight housings and re-clear them so they last another several years or so without regular maintenance to keep them clear. I need to do something about mine, they're pretty bad.
    Also found a company making an oem replacement for the headlight housing online for 30 bucks a pop on amazon (link). Not sure if I want to try cleaning up mine or just getting a new set for a price like that yet. I've had good results with sylvania's silverstars in several other cars though and will be getting a set of those for whichever solution I try.
