Lights for Toyota bull bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blueribbon, Jul 16, 2015.
  1. Jul 16, 2015 at 4:27 PM
    Blueribbon
    Blueribbon [OP] Active Member
    David
    Atlanta
    Trd off road
    Trd exhaust
    I'm thinking about getting the toyota bull bar part#00016-35800. I have a 2014 v6 4x4 TRD off road double cab.
    Question: I know these bars have ports to put lights on. Can these lights be purchased thru toyota? If so, what are the part numbers? Also, what is required to install them? do they run off of their own switch or do they connect up to the existing fog lights I already have? How hard are they to install and is there any wire splicing required?
  2. Jul 16, 2015 at 4:35 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Toyota doesn't make a bull bar.... Nor do they sell them. Are you referring to the t-force light bar?
  3. Jul 16, 2015 at 4:54 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    This is what he's referring to:
    http://www.trdsparks.com/part_detailfromlist.php?part_num=00016-35800
    It's probably something like a Westin bar being offered via dealers.
    For the OP:
    They don't run off your existing fog lamps. You don't necessarily need to splice into your factory wiring. You could measure the opening once you receive the bar and determine what size fits (4" or 6" should work well as long as they're not too deep) and then you can use the provided harness and wire to the battery and use the battery as your trigger instead of your high beam circuit and/or an ignition hot trigger.
  4. Jul 16, 2015 at 5:07 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    You can always run the DOT approved lights from Rigid as well if you're looking for something that will be legal across the board to drive with. A big plus for those.
  5. Jul 16, 2015 at 5:07 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    As mentioned above, I would wire them to a separate switch. You can easily tap into the + wires from the factory foglights if you do not want to run all that wire or. "Y" the + positive wires from the foglights to the battery, then to your switch.
