Lights on dashboard cluster
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jstaco78, Jul 21, 2017.
  1. Jul 21, 2017 at 5:35 AM
    Jstaco78
    Jstaco78 [OP] Member
    Hey everyone!
    I have a 2005 V6 Tacoma 4WD 4 door. I've had the following lights show up on my dashboard for over a year now: check engine light, traction control, VSC off, VSC TRAC. At first it was intermittent now it's on constantly. I took it to local dealership multiple times. I forget the code but the tech said it was for a speed sensor. He checked all the speed sensor and cleaned the connections and couldn't find anything wrong with them. I eventually stopped taking it because they couldn't give me any answers.
    I'm hoping someone on here has had this problem and was able to find a solution. Thanks!
    ChadsPride likes this.
  2. Jul 21, 2017 at 6:31 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Toyota's will trip the VSC associated lights when the MIL is also illuminated. It just disables the VSC until the Powertrain codes are addressed and repaired.
    You need to find out what "P" code you have stored and address it. Parts stores will sometimes pull codes for you in hopes of selling you aftermarket Mexican or Chinese parts...go to the dealer for the parts if you decide to avoid any diagnosis.
  3. Jul 21, 2017 at 6:44 AM
    Jstaco78
    Thanks Jeffs68
    The P code is PO500. The dealership said it was a speed sensor malfunction but they checked everything with that and nothing was wrong.....
  4. Jul 21, 2017 at 7:37 AM
    Jeffs68
    Stock
    The wheel speed sensors send data to the Skid control ECU (ABS module), then to the Combination meter (instrument panel) and then the signal goes to the ECM.
    Most of the time the ABS module is the culprit, but Toyota did have a rash of Combination meters that caused the issue.
  5. Jul 21, 2017 at 7:41 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I had a Yaris with the same code. Had a bunch of other side effects like no ac and no electronic power steering. Turned out to be a bad cluster.
    Jeffs68[QUOTED] likes this.
  6. Jul 21, 2017 at 8:07 AM
    Jstaco78
    Thanks. I have a friend who's looking into the combination meter for me. I believe that is what Toyota reported to the main company. The bad part is they didn't let me know what they thought it was.
  7. Jul 21, 2017 at 8:09 AM
    Jstaco78
    The only issues I've noticed, which I don't know if they are related or not, cruise control works sometimes and sometimes not, bell that rings when door is open is sometimes delayed or intermittent. And, of course, I have no traction control.
  8. Aug 21, 2017 at 4:24 PM
    Mataleo
    Mataleo New Member
    05 Toyota Tacoma Pre Runner
    Jstaco did you ever get this resolved? I have the same thing as you.
  9. Aug 21, 2017 at 4:27 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  10. Aug 21, 2017 at 4:34 PM
    Jstaco78
    Mataleo, unfortunately not. I started a new job that requires a commute so I've been busy with that.
  11. Aug 21, 2017 at 4:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Read this thread, but start with post 7. Please note it appears your shop did not follow the full FSM diagnostic procedures. Which is concerning.
    https://www.tacomaworld.com/threads/p0500-code-vehicle-speed-sensor.434829/
    Jimmyh likes this.
  12. Aug 21, 2017 at 4:49 PM
    Jstaco78
    Wow! That really does sound like the issue. I have a friend who does some of my work. I'm going to share this info with him. Thanks!!
  13. Aug 23, 2017 at 12:18 PM
    Mataleo
    Mataleo New Member
    Clearwater Bill, thank you sir, i will give it a look and see if i can fix it.
