Lights on!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TomaGirl, Oct 5, 2011.
  1. Oct 5, 2011 at 9:03 AM
    TomaGirl
    TomaGirl [OP] Well-Known Member
    Ticia
    Colorado Springs
    08 Off Road TRD
    3 Inch lift, Bull Bar, Leer Topper, TRD custom seats,Westin Nerf Bars, Pro Comp wheels, Custom grill, TRD cat back exhaust system, Door sill protectors and more will be added
    I have a 2008 Tacoma Off Road 6 cylinder and my TSB light and Maintenance light have been on for about two weeks now. I am at about 36,000 miles so i'm assuming i need a tune up or something, but can someone tell me what is required with that and also can I get some advice on a good reasonable shop here in Colorado Springs to take it in to get this done.
    Thanks for your help.
  2. Oct 5, 2011 at 9:06 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    whens the last time you had your oil changed?
    and tsb light....you mean your tpms (tire pressure measuring system)?
  3. Oct 5, 2011 at 9:16 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The "Maint. Req" light comes on flashing at 4,900 miles (I believe) and comes on solid every 5,000 miles to remind you to change your oil. Change your oil and reset the light by turning the truck off, cycle through your ODO until your odometer is showing (not the trip ODOs) and hold the selector button down while turning the key from off to on (don't start it, just turn it to 'on'). Hold for 5 seconds and your ODO will flash 00000 and it's reset for another 5,000.
    The light with a tire in it is for the Tire Pressure Monitoring System and comes on if there's a fault in the system or if one of your tires is low on air. Check your tires (including the spare) and reset the light with the button below the steering wheel.
    All this is in your owner's manual by the way, there's an entire section that shows every fault light, what it means and how to correct it. :thumbsup:
  4. Oct 5, 2011 at 9:21 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Lol.. If you were a guy, this would be everyones answer..
  5. Oct 5, 2011 at 9:23 AM
    Pugga
    Massachusetts
    F-150 Mod
    It was a weak moment :eek:
  6. Oct 6, 2011 at 7:28 AM
    TomaGirl
    Ticia
    Colorado Springs
    08 Off Road TRD
    Thanks for the info on the service lights being on. I appreciate the helpful comments, but could have done without the smart ass comments by the ohter immature guys. You happen to be "one" of the decent few.
  7. Oct 6, 2011 at 7:32 AM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    What he said and double down on reading the owner's manual. It will take care of alot of the worry and wondering with your truck.
  8. Oct 6, 2011 at 7:33 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
  9. Oct 6, 2011 at 7:33 AM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    I take exception to that remark.
    There are no decent people on this forum. :D
  10. Oct 6, 2011 at 7:39 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Welcome.
    The guys are really helpful when needed, but are smart a$$es when people ask before searching or reading their owners manual.
  11. Oct 6, 2011 at 11:18 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    There are more than just a few. Most of us will help but with almost 45K members you are bound to get some smart a$$ answers. Just ignore them and read the helpful ones.
  12. Oct 6, 2011 at 11:28 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i see this thread reaching 10 pages just cause op is a girl
  13. Oct 6, 2011 at 11:30 AM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    This.
