Lights out! Please help....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by only_one, Jun 4, 2009.
  1. Jun 4, 2009 at 7:48 PM
    only_one
    only_one [OP] 08 TRD Off-Road 4x4
    Arizona
    08 Speedway Blue 4x4
    ok so I have had the black headlights with halo rings and LEDs for a while now. All of a sudden the other day the parking lights quit working. Both the low beams and high beams still wor but the parking lights used to turn on the halo rings and LEDs. I thought at first the headlights were just bad or something but when i drove it that night none of the interior dash lights except the speedo and tach area would work. Im thinking it could be a fuse or something but the damn manual is so confusing about fuses. Any ideas or quick fixes?
  2. Jun 4, 2009 at 7:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    Unconfuse yourself about the diagram for the fuses- There are some under the dash and some under the hood- Find them and check them (Check every one if you can't figure out which one goes to the lights).
    If that's not it...Check all your ground for the new lights.
    other ideas will follow I'm sure.
  3. Jun 4, 2009 at 7:52 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    check the fuses, their is two fuse boxes, one in the cab by the hood release and the other by the battery, if you open either one the cover has a diagram on the inside cover, just look for parking lights or something that has to do with lights, if it is blown the metal inside the fuse will be black or broken.
  4. Jun 4, 2009 at 7:52 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    #1 Fuses
    #2 Bad ground
    #3 bulbs bunt out
    #4 ummm thats it
  5. Jun 4, 2009 at 7:54 PM
    only_one
    Arizona
    its gotta be the fuses...i just didnt wanna pull every single one. i figured someone would know. the ground has been good for a year and there is no way all those bulbs went out at once.
  6. Jun 4, 2009 at 9:34 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Means nothing. :p
  7. Jun 4, 2009 at 9:48 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    gotta be a fuse
  8. Jun 6, 2009 at 2:30 PM
    only_one
    Arizona
    Alright I found the fuse that was blown. I replaced it and turned on the lights. I could hear it blow right away again. I tried it one more time with the radar detector out of the accessory outlet and the truck off. Turning on the lights again blew the fuse. So now I need to track down the short somewhere that is causing this...any ideas? I'm lost on where to even start.
  9. Jun 6, 2009 at 2:37 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Check the ground....
  10. Jun 6, 2009 at 2:53 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    x3
    It's the number one electrical gremlin!
  11. Jun 6, 2009 at 3:32 PM
    only_one
    Arizona
    the ground for what?
  12. Jun 6, 2009 at 3:33 PM
    only_one
    Arizona
    sorry for my electrical stupidity i am a aircraft mechanic and do not deal with electronics.
  13. Jun 6, 2009 at 3:58 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    No need to apologize, there is no stupidity...
    There should be ground wires from your lights, wiring always has a positive and negative. Electrical is a push pull system... Anyways, look at your headlights and trace your ground wire (mostly everytime it is a black wire, positive is usually red or white). If it's not "grounded" properly there will be a short. Most likely an exposed wire contacting something bad. Or sometime it's grounded back to the body and it's loose. Either way, start at the headlights and work your way through the wiring harness. I'm sorry I don't have a better description for you as I haven't installed these lights.
    Good luck and take your time. Keep a few more fuses handy to test it out. It mos def sounds like a ground issue as your blowing fuses...
    Rob
  14. Jun 6, 2009 at 4:08 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    meh, you mess with the electrical system install ghetto lights, etc., you get the shit that comes with it. Don't be so bored, some mods are booby traps.
  15. Jun 6, 2009 at 4:11 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You may need to trace the wiring too... Possible it's shorting to the body somewhere (mouse or something could have nipped it).
