Lights suitable for every day use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Jan 12, 2012.
  1. Jan 12, 2012 at 7:10 AM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    Hi Folks,
    I am getting an EE light bar to go behind my Satoshi. I need some help choosing the right kind of lights to get. I know HIDs such as Kragens are popular, but I would prefer something that I could use everyday, in conjunction with the low beams.
    Are there any options for decent light output, while still keeping it legal for around town and highway use? All my searches only turned up "offroad use only" lights.
  2. Jan 12, 2012 at 7:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lights mounted that high up are kind of high to be used in conjuntion with the low beams (typically you run fog lights with low beams and they should be low to the ground and have a wide, short beam pattern). Have you considered a driving light that would suppliment the high beams? Typically they are mounted higher up and have a long, narrow beam.
  3. Jan 12, 2012 at 9:31 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
  4. Jan 13, 2012 at 5:34 AM
    xxaarraa
  5. Jan 13, 2012 at 5:46 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think you might find that using lights like that will get you a ticket in most places. Many of those places require Auxiliary lights to be covered unless you are off road and have a very limited number of times (if at all) that you can energize those lights on road.
  6. Jan 13, 2012 at 5:50 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    why do you say PIAA's dont last long? Ive been running the same set for around 4 years now and no problems whatsoever. I use them every morning on my drive to work, back roads and about 4am so i rarely see another car and when i do i turn them off long before i get to them. but i couldnt be happier with my PIAA's have some 540's and 520 atp's. 4 years seems pretty good to me????
  7. Jan 13, 2012 at 5:19 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Its not every set, ive just seen a lot of them break, get leaks and get damaged after a short amount of time. A lot of reviews talk about the quality on Hella being better, even tho piaa's can be good.
    Lightforce's are the best. They use a high grade glass that dosent scratch or break. Theres a video of it being hit with a 12 guage and not breaking.
  8. Jan 13, 2012 at 5:29 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Lightforces use plastic covers, plasic lights, lenses, everything.
    In that same video he bounces the light around like a basketball.
    Those covers are damn tough though. I've had a lot of big rocks on the highway hit them, no problems.
    Plus you can focus them!
    They are no good for the road though, they don't have a lower shield to cut the high beam off so they will blind people. As will every light that isn't a low/high beam basically.
  9. Jan 14, 2012 at 4:10 AM
    xxaarraa
    So if we run the lights behind the Satoshi (which is what I am intending to do), do we still need to run them with the protective covers on? I would think no, but thoughts?
  10. Jan 14, 2012 at 4:24 AM
    ANGUS
    ANGUS Well-Known Member
    Beckley, WV
    06 SR5 4cyl
    3in rough country, front adj bilstiens 5100s, volant cold-air intake, magnaflow exhaust, optima yellowtop, 4.56 motive gears rear, 4.56 nitro gear front with v6 front diff carrier, brute force fab front bumper, 6k hid, 1.25" wheel spacers, 15% window tint, cab lights, color matched bushwackers, trd hood
    I don't know the laws where you are from but in wv you can run up to 2 55w fog lights in conjunction with your low beams and must be at the same height or lower. I don't think light projection matters here. But I understand being courtious to other drivers
  11. Jan 14, 2012 at 9:26 AM
    anethema
    J
    Dawson Creek,BC
    If you blind other drivers you will get pulled over eventually, legal fog lights or not. Here the ticket is 'failure to diminish lights' or something similar. Basically didn't shut off your brights and are blinding motorists.
    You don't need covers if they are behind your satoshi, just don't use them on the road. Off-road use only.
