Lights went out on my shifter/ac/and radio
Discussion in 'Lighting' started by SR52012, Mar 24, 2013.
  1. Mar 24, 2013 at 6:28 AM
    SR52012
    SR52012 [OP] Well-Known Member
    Port Richey (Tampa Area)
    2012 Taco Pre-Runner SR5 3" procomp lift
    3" Procomp lift level kit N-FAB step sides
    I dont know if this is the right place for this... but i have a 2012 and i noticed lastnight that the lights next to my shifter, around my a/c controls, anf the preset buttons on my radio are not working. I have tried turning the lights on and off and also restarting the truck but nothing. I have not checked fuses... and yes it is under warrenty... but if it was a simple fix i would do it myself.
    Any help would be great!
  2. Mar 24, 2013 at 7:27 AM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    Are your cluster lights off too? If so check the dimmer switch if not its an ign fuse left side of dash
  3. Mar 24, 2013 at 7:31 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Most likely is the tail lights fuse. That's my 1st guess. That fuse is located in the dash behind the change door thingy on the left side.
  4. Mar 24, 2013 at 7:31 AM
    SR52012
    Checked the dimmer, the cluster is working as normal.
  5. Apr 1, 2013 at 8:22 AM
    petejoneria
    petejoneria Active Member
    Germany
    2012 TRD-Off Road 4X4
    Same problem here today. I parked my truck Friday and cleaned the interior. When I drove to work today, all of the lights (cluster/radio/AC) were out. My radio was set to AUX, so I didn't hear anything. Long story short, it was the dimmer. I've had cars that I could dim pretty low, but the Tacoma can turn them off completely. I did have fun checking all of my fuses before I found this thread.
  6. Apr 1, 2013 at 8:56 AM
    SR52012
    I checked my dimmer as well, but my guages dim along with the other lights... and those are working fine.
  7. Jun 25, 2015 at 11:27 AM
    minuteman
    minuteman Member
    Western Pennsylvania
    12 Double Cab Long Bed SR5
    Midland cb, K30 antenna, n-fab running boards, k&n air filter, truxedo tonneau cover, Blue Sea Fuse Box with 100 amp breaker, LED Bed Lights, LED Light Bar, Avid Bumper.
    Mine has just started doing this. Did you find out what was causing it?
  8. Sep 22, 2017 at 5:51 PM
    Jerrck
    Jerrck New Member
    Black 2013 taco
    Just bought it and didn't realize I have the same issue. Just checked the fuses and they are all good to go. Anyone got any other ideas?
