Lights won't turn off
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Sep 8, 2016.
  1. Sep 8, 2016 at 10:44 AM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    I just installed some HIDs from TRS and noticed the lights will turn off and on fine when the truck is started and the parking brake is engaged. If I disengage the parking brake the lights turn on immediately! Is this a safety feature? If so can I disable the auto-on? I can't remember if it did this with the halogens. Do your lights do this? I read some Toyotas have a positive ground (whatever that is) which could cause problems where the lights won't turn off. Is that a possibility?
  2. Sep 8, 2016 at 11:22 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    My Wife's 2007 Rav4 does that exact thing. I know of no way to disable the DRL's.
  3. Sep 8, 2016 at 11:25 AM
    timhom19
    timhom19 Well-Known Member
    tim
    Beaumont, Ca
    2010 DCLB
    Mine did the same thing I think it's because the hid lights are connected straight to the battery. They are not connected to the kill switch when u open the driver side door.
  4. Sep 8, 2016 at 11:25 AM
    timhom19
    tim
    Beaumont, Ca
    2010 DCLB
    I could be way off tho.
  5. Sep 8, 2016 at 11:28 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    What year is your taco?
  6. Sep 8, 2016 at 11:29 AM
    timhom19
    tim
    Beaumont, Ca
    2010 DCLB
    2010. Just saw u r a 1st Gen so could be different. My bad.
  7. Sep 8, 2016 at 11:36 AM
    pontoon
    Mine is 2000.
  8. Sep 8, 2016 at 1:38 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    That's not normal for a 2000. I believe some double cabs of 2001-2004 have DRL.
  9. Sep 8, 2016 at 2:08 PM
    pontoon
    It might be a 2002 actually. I can't remember. It has the square-ish headlights.
  10. Sep 8, 2016 at 3:49 PM
    Your-10Ply-Bud
    Your-10Ply-Bud Should be fine, not my truck..
    Marshall
    Ontario, Canada
    2001 3RZ 4x4 5spd
    5-Stars/Satoshi 5100's/OME 881's TG AAL/Cooper AT3's
    Not just double cabs, my 01 extra cab has DRL's come on as soon as my parking brake get released as well. Not sure how to go about disabling them but maybe check some wiring diagrams if you have access
    DustStorm4x4[QUOTED] likes this.
  11. Sep 8, 2016 at 4:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    So your title isn't correct. They do turn off. Either by shutting the vehicle down or engaging the parking brake, correct?
