lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greatshepherd, Oct 24, 2012.
  1. Oct 24, 2012 at 1:56 PM
    greatshepherd
    greatshepherd [OP] Member
    west virginia
    tacoma 4x4
    I have no front parking lights or dash lights. I checked every fuse in both fuse boxes and have power to all except no. 24 underhood fuse box 7.5 amp sta, please advise
  2. Oct 24, 2012 at 2:00 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you don't have tail lights either then it's a fuse. I had the same thing happen to me a while back. It should be a 10A fuse in the underhood panel. I can't remember which one off hand but I think it's the tail light fuse.
  3. Oct 24, 2012 at 2:16 PM
    greatshepherd
    west virginia
    tacoma 4x4
    i have tail lights
  4. Oct 24, 2012 at 2:17 PM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    What else doesn't work?
  5. Oct 24, 2012 at 2:44 PM
    NHCrewcab2008
    NHCrewcab2008 Well-Known Member
    Thornton, NH
    SR5 TRD
    What type of work or mods have you done to the truck in the last 2 weeks? it may help us back track the issue.
  6. Oct 24, 2012 at 5:00 PM
    greatshepherd
    west virginia
    tacoma 4x4
    i just wired in a 3 prong toggle switch for my fogs in place of the factory 4 prong fog switch.
  7. Oct 25, 2012 at 6:57 PM
    greatshepherd
    west virginia
    tacoma 4x4
    please help i have no front park lights or instament panel lights all the fuses under dash are good
  8. Oct 25, 2012 at 8:06 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Do me a favor and check Ign.1 No.2, I had radio, headlights, dash lights, windows and some other die and it was that fuse.
    1: Check the ones under the hood
    2: go down the line and replace each one with a new one, until the problem goes away.
  9. Oct 25, 2012 at 8:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    How and what did you do... and why?
    The stock 4-prong switch is:
    1 - Fog Relay
    2 - Fog Relay
    3 - Dash lamps
    4 - Ground
    If you screwed with that, you could have burned wiring, damaged the lights switch in the turn signal stalk, or burned out the dimmer.
    Edit... don't use the above as a wiring diagram... tha's just an example and not the actual pinouts.
  10. Oct 27, 2012 at 2:35 PM
    greatshepherd
    west virginia
    tacoma 4x4
    wow thanks so much lt was a burnrd out dimmer/ who would imagine?
