Lights
Discussion in 'Lighting' started by labman626, Jan 9, 2013.
  1. Jan 9, 2013 at 7:06 AM
    labman626
    labman626 [OP] Member
    I posted this in another thread before I new there was a forum about it. How can I clean my headlights they are dirty on the inside and how Can I change the light bulb on my interior overhead light it blew out.
  2. Jan 10, 2013 at 3:38 PM
    GrM25
    GrM25 Well-Known Member
    Grant
    2015 SR 5spd 4x4
    The map light or dome light? For the dome light, the light cover on the interior lights just pop off. Use a flathead screw driver and pry the cover off (there is a little slit at the end of the light to insert the flathead) start there and then work your way around the light till it comes loose (the light cover is attached to the truck by a hinge so the cover won't come all the way off). Then you can take the bulb out and replace it.
  3. Jan 10, 2013 at 3:41 PM
    GrM25
    Grant
    2015 SR 5spd 4x4
