Lightweight 16x7 wheels?
Discussion in 'Wheels & Tires' started by Josh-L, Oct 25, 2020.
  1. Oct 25, 2020 at 11:21 AM
    Josh-L
    Josh-L [OP] Well-Known Member
    2021 Silver SR DCSB V6 4x4
    I have been looking for some new wheels and want to stay stock size. I can’t seem to find anything I like. I wanted done @SCSPerformance F5s but they are 16x8. What are you guys running in 16x7 size?
    mallege likes this.
  2. Oct 25, 2020 at 1:26 PM
    mallege
    mallege Well-Known Member
    George
    SW Idaho
    2019 Tacoma SR Gray SB Auto V6
    Extang tonneau cover, variable speed wiper stalk, hood struts, ScangaugeII.
    I'm running some stock tacoma wheels that I found on craigslist.
    Hooper89 likes this.
  3. Oct 27, 2020 at 8:07 PM
    FishTaco805
    FishTaco805 Active Member
    P
    2020 Tacoma TRD Offroad 4x4
    Just curious..why not go to 16x8? It still uses the same 16" tires, just less side bulge to look at.
    whatstcp likes this.
  4. Oct 28, 2020 at 7:11 AM
    Josh-L
    According to tirerack.com the recommended wheel width for 235/85 tires is 6 - 7.5. So that’s why. I also like a little bit of bulge for curb rub protection lol. And they’d be even lighter than the 16x8s.
  5. Oct 28, 2020 at 7:28 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Scrounge around on Discount Tire, Tire Rack, Fleecebay and other Google search results. IIRC there is a place in TX called American Wheel handling remanufactured wheels.
    What are you thinking as a "light weight" wheel? Weight range in mind?
  6. Oct 28, 2020 at 7:47 AM
    Josh-L
    20 pounds or less.
  7. Oct 28, 2020 at 7:57 AM
    Knute
    You may need to find a wheel made of Mg.
    Not sure, if an Al wheel in the 16x7 size will be <20 lb.
    Good luck.
  8. Oct 28, 2020 at 10:41 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    stock steel toyota truck wheels, any of the aluminum? Tacoma wheels, all 16x7 and not too heavy.
    sub 20? Why?
  9. Oct 28, 2020 at 10:47 AM
    Josh-L
    Just going off what the SCS F5 weighs which is 18 and some change.
  10. Oct 28, 2020 at 10:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Your fault for running a skinnier-than-stock 235/85 tire? :p
    Not aware of any lightweight aftermarket 16x7 wheels in our lug pattern. The OEM 2nd gen 16x7 TRD Off Road wheels I'm running are 20 lb each. Konig Countersteer 16x8s are 16 lb each.
    Josh-L[QUOTED][OP] likes this.
  11. Oct 28, 2020 at 12:50 PM
    FishTaco805
    P
    Gotcha. Makes sense. U going the tall and skinny route..sweet!
