Like my Tacoma NOT!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OlFart44, Jun 4, 2024.
  1. Jun 4, 2024 at 10:20 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I'm sure they will. Not everyone cares about these things the same way. Some people will never tow, use the truck in cold weather or even look at the fuel economy screen in the radio. It doesn’t mean those limitations or issues don’t exist though.
  2. Jun 4, 2024 at 10:20 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Could have been drug out of the river to...
    Pwakchop[QUOTED] likes this.
  3. Jun 4, 2024 at 10:21 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Depends on carrier. However there have been cases where a vehicle will get totaled due to parts shortage. Although with some of the electrical gremlins going on this might not be the case?
  4. Jun 4, 2024 at 10:21 AM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    There are hundreds of members on this forum that tow in below freezing weather constantly and don't complain one bit. Maybe they are not as sensitive, but surely a few would pop up if it really was a major annoyance. Cold weather towing will always reduce MPGs, ESPECIALLY with 285s.
    BC Hunter and Junkhead like this.
  5. Jun 4, 2024 at 10:23 AM
    Pwakchop
    Nate
    Georgia
    Pop a door panel and look for a water line, this theory would make sense especially with electrical issues. No regular truck that hasn't been through some hard stuff would act like this.
    HondaGM[QUOTED] likes this.
  6. Jun 4, 2024 at 10:25 AM
    Doc2
    Doc2 Well-Known Member
    NE GA
    2020 Tacoma SR5 Doublecab 6cyl
    Nerf bars, bed mat, anything I can think of!
    Wow! I love my 2020! I wouldn’t love it if it was like yours. Sorry you got a lemon.
    Junkhead likes this.
  7. Jun 4, 2024 at 10:27 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  8. Jun 4, 2024 at 10:27 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Sounds like a virtual lemon. All makes/models have some which is why you test drive and have it checked by a mechanic YOU trust. You could try changing tire sizes and I’m not buying the stealership’s take on a reflash w/ a different tune since that’s a common fix for 3rd gen shift issues and don’t use overdrive for towing. With oversized tires on your mileage may not be as bad as indicated since odo and Speedo are both erroneous therefore the display is as well. Can’t speak to the collision avoidance issues other than possibly a consequence of prior collision coupled with dealers inability or incompetence to address it or figure it out but barring a fix there I doubt you’ll ever be happy behind this particular wheel.
  9. Jun 4, 2024 at 10:28 AM
    Pwakchop
    Nate
    Georgia
    :eek: Wouldn't be surprised if the VIN matches [​IMG]:rofl:
  10. Jun 4, 2024 at 10:29 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Can we get a new subforum for bitching? I'd get it if OP had questions, but seems like there's been an influx of newish members with nothing good to say about their trucks.
    Like, why are you here, and why do you still have the truck if you hate it so much?
    Edit: I did see OP was asking for input, my bad.
  11. Jun 4, 2024 at 10:29 AM
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    No, that's a myth. There is no such rule (well, other than in Texas, kinda sorta, depending upon which .gov documents you read). There are some states with title branding rules, as in "If the repairs are x% of the value or higher, you must place the vehicle on a salvage title," but that's much different than "It's not a total unless the damage is x% of the value."
  12. Jun 4, 2024 at 10:31 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    @chris4x4 We need a new subforum with a Poll Please..
    chris4x4 likes this.
  13. Jun 4, 2024 at 10:32 AM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I have a 21 Off Road and have none of these problems (well maybe can empathize with slight gear hunting in the steep hills). I've run it in -20F temps and it runs great. I get 20mpg in town, 23+mpg at 65mph on long highway trips on stock tires. Do larger tires hit mpg that hard?? Sounds like something is wrong...
  14. Jun 4, 2024 at 10:38 AM
    Pwakchop
    Nate
    Georgia
    Same exact experience here. Upgraded from 265/65r17 to 275/70r17 and lost 5 MPG because of the weight, calculated using GPS and calculator. Went back to stock ASAP. These trucks hate heavy tires. Some light 265/70r17s are the next step for me.
    Vmax540 likes this.
  15. Jun 4, 2024 at 10:38 AM
    #35
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s a combination of heavier tires, higher profile, and inaccurate display probably exacerbated by lemonitis.
    gsubioguy and HondaGM like this.
  16. Jun 4, 2024 at 10:40 AM
    #36
    TacoOption
    TacoOption Well-Known Member
    Have you yourself owned a 3G?
    WallyIAm, HondaGM and Pwakchop like this.
  17. Jun 4, 2024 at 10:44 AM
    #37
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Did you test drive it?
    Buy a real truck, these are light duty at most which is what I mostly needed.
    Nothing wrong with that, works for me but I have a full size too for big truck things & towing.
  18. Jun 4, 2024 at 10:48 AM
    #38
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I have. Towed with a ton, had 33's on it and drove in below 0F weather up and over many Rocky Mountain passes. I purchased a manually specifically to avoid the transmission related headaches so I can't speak from personal experience on those, other than what I noticed as a passenger in friends' Tacomas.
    HondaGM likes this.
  19. Jun 4, 2024 at 11:18 AM
    #39
    JCox
    JCox Well-Known Member
    Justin
    2021 Tacoma SR5
    Couldn’t agree more. I’ve hopped in vehicles, loved them right from the lot to trade, this one I own now - talk about a relationship. Fussy, sometimes great, sometimes not so great, all over the place. It’s a beautiful truck but not a grounded one.
    MindlessCorpse likes this.
  20. Jun 4, 2024 at 11:43 AM
    #40
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    Other than trade? Try to sell it privately (full disclosure). If that fails, you could take it to a remote location, light it on fire, tell authorities it was stolen, make insurance claim. Good luck.
