Likely totaled truck...i want the damn tailgate though!
Discussion in '1st Gen. Tacomas (1995-2004)' started by el dudarino, Feb 16, 2012.
  1. Feb 16, 2012 at 8:27 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    you dont have 2 large bolts holding it in at the bottom? On my 99 and my 96 it has bolts. to get it off you need the 14mm (i believe) ratchet and an extension. then once those are off you can take off the black cables
    most people consider those brush guards to be damage multipliers.
  2. Feb 16, 2012 at 9:50 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Unfortunately a brush guard like that wont do shit in an accident. Those are good for keeping sticks and branches off your lights and for pushing around shopping carts...thats it :eek:
  3. Feb 16, 2012 at 11:11 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Not that I remember. I only took the tailgate off once and don't remember any bolts.
  4. Feb 17, 2012 at 12:13 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I wonder how something serious like an ARB would have fair in the OPs accident.
  5. Feb 17, 2012 at 12:23 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    ARB has crush zones built into the mountain brackets. I bet the airbags would have still deployed. ARB claims that they do not interfere with airbag deployment. Now had it been a Relentless or an Elite well the taco would have ate the other car for lunch. From what I've seen they eliminate the factory aluminum crumple zone...
    OP glad you're doing well. Lawyer up! It took me two and a half years to settle with insurance after I got hit by a drunk driver and that should have been pretty open and closed case but it ended up in court for 6 months. And i still deal with the pain from the crash on a daily basis. Get all the money you can because you never know what medical surprises you'll see down the road because if this crash.
  6. Feb 17, 2012 at 12:41 AM
    x2468
  7. Feb 17, 2012 at 12:52 AM
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    Glad that you are ok buddy. good luck on the case. Hopefully the tides are in your favor.
    but if you are looking for protection do not get a brush guard. the are call cosmetic looks.
    get a steel bumper for that
    i rear ended a lady in mine almost 5 hours after i mounted it up!
    after i slammed on my brakes and skidded into her rear end i was going about 10 to 15 mph...
    the picture is about 1 hour after the accident.
  8. Feb 17, 2012 at 6:31 AM
    el dudarino
    el dudarino [OP] Well-Known Member
    Thanks everyone...glad I'm ok too. Someone always has it worse and I walked away from this relatively unscathed. I really wanted an ARB or some other type of aftermarket bumper, but I just wasn't at that point in my build yet. It was going to be a camper shell, suspension, tires, armor.
    With your case or anyone else in here...are you in court a lot and have to miss a lot of time from work. Do the lawyers typically fight it out? Never dealt with this kind of thing before.
  9. Feb 17, 2012 at 6:48 AM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I have had to use mine unfortunately......they are very good at totaling jettas under 20 mph
    only one small bend in it that cant be seen form this pic.....did a number on the jetta...i wish i had thought to get pics
  10. Feb 17, 2012 at 8:01 AM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    What's odd is that someone just posted the other day that there had been 2 wrecks and that these things always come in three's, now here is the third. Glad you are okay!
