Limit Slip Dif HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wille, Dec 23, 2013.
  1. Dec 23, 2013 at 5:06 PM
    Wille
    Wille [OP] Member
    Lima
    2010 Takoma
    Suspention
    Looking to buy a Limit-slip for my 2010 double cap 4x4 Tacoma.
    Would appreciate your recomendations.
    Thanks, Wille
  2. Dec 23, 2013 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Detroit tru-trak
  3. Dec 23, 2013 at 6:14 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    What he said ^^^
  4. Dec 23, 2013 at 6:35 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    What truck do you have - SR5, Sport or OR. Why do you want a LSD? The True-Trac wouldn't be my choice if I were looking for Off Road performance.
    David
  5. Dec 23, 2013 at 6:44 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    ??? Didn't your truck come with LSD???
  6. Dec 23, 2013 at 6:54 PM
    Canazes9
    David
    Texas
    Yes, no, maybe, sort-of....
    If he's looking for LSD that's not engine limited by traction control in 4wd I hope he bought the Off Road, other wise....
    David
  7. Dec 23, 2013 at 8:41 PM
    untuckedtaco
    untuckedtaco Well-Known Member
    Kyle
    Chesapeake 23323
    DCSB 08 SAS'ed/REBUILDING
    Surprises
    I have the true-trak and love it
  8. Dec 25, 2013 at 8:22 PM
    Wille
    Wille [OP] Member
    Lima
    2010 Takoma
    Suspention
    I have a 4x4 2010 Tacoma double cap and the rear dif does not have a LSD
    Wille
  9. Dec 25, 2013 at 8:24 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    TRD sport does
  10. Dec 25, 2013 at 9:25 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Only 05-08 sport models came with real LSD. 2009+ comes with auto-LSD which is a LSD simulated with the brakes.
  11. Dec 25, 2013 at 9:33 PM
    Manwithoutaplan
    ID
    I have a limited slip laying around if you would to purchase it it is from 2007 sport. Pulled out last year because I put arb front and back.
  12. Dec 26, 2013 at 2:59 AM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    The electronic LSD on the sport sucks . Shouldnt even be allowed to be called LSD . A clutch type LSD would of been nice for those of is that don't need a locker .
  13. Dec 26, 2013 at 3:04 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I've been considering one of these
    please excuse the newbness of this question and the partial-thread-jacking:
    Is an LSD (in the rear) more or less likely to kick out/walk on you than an Open Diff in slippery conditions, like ice?
    I know how an LSD works and when I picture the scenario in my head, I can come up with both...
    My first and only experience with an LSD was being a passenger with someone who didn't know that the car had an (rear) LSD; he tried to swing the rear out and fish-tail around a 90 degree corner on a dirt road; and the owner (also passenger at the time) screamed "NO, IT'S A POSI!!" as we careened straight into the ditch, because it didn't swing-out...
    Does that answer my own question?
    Would an LSD be less likely to violently kick out on you in slippery conditions?
    cause, like I said, picturing the mechanics of it in my head; I can envision it, at least in certain situations, being more likely too
  14. Dec 26, 2013 at 8:55 AM
    TR90125
    TR90125 Well-Known Member
    North Texas
    2013 DCSB TRD Sport
    Bone stock for now....
    Agreed.
  15. Dec 26, 2013 at 10:14 AM
    Wille
    Wille [OP] Member
    Lima
    2010 Takoma
    Suspention
    Interested, please e-mail a pictures and what you want for it, Thanks
    jalexwille@hotmail.com
  16. Dec 26, 2013 at 10:39 AM
    Manwithoutaplan
    ID
    Email sent John ^
  17. Dec 26, 2013 at 10:52 AM
    replica9000
    2019 T4R ORP
    POSI is GM's name for limited slip. My 2000 Trans Am WS6 had one and it did alright in the snow. It stayed straight most of the time unless I was purposely trying to kick out the rear end.
    My 1986 V6 Camaro had an open-diff. It was underpowered, and even had snow tires on it. If I wasn't careful, I was instantly doing a 180 in traffic.
    My 2008 Tacoma has the real LSD, and it does alright in 2wd. Any troubles getting around in snow is usually because the rear end is lighter than the front end. It still stays inline unless I give it too much gas.
  18. Dec 26, 2013 at 4:32 PM
    TRD Toy85
    CT
    WS6 in the snow :eek:, I dont think I can get myself to drive that in the rain ! lol
    Such awesome cars !
  19. Dec 26, 2013 at 6:20 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    It depends on which limited slip you are using. For example Eatons' Truetrac will hold traction but when single wheel loses completely it will act like open diff.
    If you are using LSD from original Tacoma (Hino) that diff will power both wheels until both lose traction. So it will provide traction longer but when it loses traction it's going to be on both wheels, sending rear end either to left or right.
    This is especially dangerous driving in mountains. However, benefit of LSD is that with couple bags of send you will not need 4x4 as often as you would need by having open differential.
  20. Dec 26, 2013 at 10:48 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Not mechanical LSD since the 2008 model... All Tacomas have AUTO LSD and TRAC limited slip. Only the Off Road has more traction available from the factory.
