Limit switch for hood lights?
Discussion in 'Lighting' started by Reh5108, Feb 9, 2014.
  1. Feb 16, 2014 at 3:23 PM
    Slider57
    Slider57 Active Member
    Bailey, CO
    14 ACSB 4WD SR5 V6
    So, political and safety rant BS aside, using a mercury switch underhood, what would a wiring diagram look like?
  2. Feb 16, 2014 at 3:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The mercury makes contact between two pins, just like a toggle or pushbutton.
    Difference is you can put the switch on either the hot or the ground side... I'd put it on the hot side, so...
    Battery - - - - Fuse - - - - Switch - - - - Light - - - - Ground
  3. Feb 19, 2014 at 8:07 PM
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
  4. Feb 19, 2014 at 8:27 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Very nice, clean install.
  5. Feb 19, 2014 at 9:11 PM
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
  6. Feb 20, 2014 at 7:15 AM
    Slider57
    Bailey, CO
    14 ACSB 4WD SR5 V6
    Ahhh. Got it, thanks Rich!
  7. Mar 12, 2014 at 2:39 PM
    Reh5108
    Idaho
    This is what I ended up going with. Got if from the the guys selling the hood light kit on here. edepagyg_77c0047f3ace1d6996a756f8268b41513c10b3c5.jpg
  8. Mar 31, 2014 at 1:54 AM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    where did you get that light?!looks legit
  9. Mar 31, 2014 at 3:17 AM
    Reh5108
    Idaho
  10. Apr 21, 2014 at 3:36 PM
    skygear
    skygear                    
    if you people did the RedLine hood struts. Get a Gas prop Switch.
    [​IMG][​IMG]
    o0oSHADOWo0o likes this.
  11. Apr 22, 2014 at 4:28 AM
    skygear
    skygear                    
  12. Jul 8, 2016 at 7:47 AM
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    Has anyone else tried a gas prop switch on Redline struts other than the banned guy above?
    I contact Redline to see what they say.
  13. Jul 8, 2016 at 8:07 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Some newer cars if they are lucky to even have a hood light use a switch similar to a mercury switch. But use a ball in a tube to activate. Mine does and j have never noticed it flickering while driving.
  14. Jul 8, 2016 at 4:48 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I used a a magnetic Anzo brand switch. When the magnets are together they shut the hood lights off and when you open the hood and they come apart the lights come on. I also have an auxiliary switch to turn the lights completely off if I'm under the hood during the day. Simple and doesn't take up any room. Just two small magnets one on the top of the inside of the hood and the other on the piece of metal running across right in front of the battery
  15. Jul 8, 2016 at 4:54 PM
    #35
    justchil
    Andy
    WV
    13 AC TRD OR
    This the one? That's a good idea and pretty much foolproof.
  16. Jul 8, 2016 at 4:55 PM
    #36
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Yes that is the one!
  17. Jul 8, 2016 at 5:20 PM
    #37
    justchil
    Andy
    WV
    13 AC TRD OR
    Thanks for the idea. I found another one I'm going to try that's a little smaller. I'm looking for a low amp micro relay to tuck away just to be safe.
    https://www.amazon.com/Directed-Electronics-8600-Magnetic-Switch/dp/B0009SUEZY/
    I ordered 4 of these to try out. I'll at least use two under the hood. Maybe put a couple down in the engine bay and see how they hold up to water. I don't see an IP rating or anything but they are cheap and look to be good quality.
    http://www.vleds.com/aluminum-bar-light-striplight-3-chip-15-led.html
  18. Jul 12, 2016 at 8:11 AM
    #38
    justchil
    Andy
    WV
    13 AC TRD OR
    My switch came in yesterday. I will post up some photos in case it may be useful to someone in the future.
    The switch is very small :D
  19. Jul 13, 2016 at 7:16 PM
    #39
    justchil
    Andy
    WV
    13 AC TRD OR
    The magnet switch worked for a few minutes then quit working. I read in the reviews about others having the same issue.
    So back to the normal switch for me.
  20. Jul 13, 2016 at 8:19 PM
    #40
    Sicyota04
    Morgan
    California
    04 DC 4x4
    This one works perfect still. And has an auxiliary switch to turn off during the day when the hood is up.
