limited power
Discussion in 'Performance and Tuning' started by aktarus, Oct 23, 2009.
  1. Oct 23, 2009 at 1:34 PM
    aktarus
    aktarus [OP] Member
    hi to everybody
    I write from Rome Italia,
    I send to all one embrace!!
    to be to buy toyota tacoma in USA,
    I wanted to know if the power and the maximum speed to be limited.
    can you answer?
    thanks
    Aktarus
  2. Oct 23, 2009 at 1:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    The V6 Tacomas are rated from the factory at 236 h.p. I belive the top speed to be limited to 112 Mph.
  3. Oct 23, 2009 at 1:39 PM
    aktarus
    aktarus [OP] Member
    [quote = chris4x4; 1.054.345] Benvenuti a TW!
    Il Tacomas V6 sono classificati dalla fabbrica a 236 CV I belive la velocità massima di essere limitata a 112 Km / h. [/ Quote]
    thanks for your fast answer!
    can you/he/she be brought to a taller speed?
    thanks
  4. Oct 23, 2009 at 1:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I belive the speed limiter can be raised with an aftermarket programmer, but Im unsure of what one does this. However, you should re think this, as it IS a truck, and not designed for high speeds. Most tires for trucks are only rated to 115 mph, or lower.
  5. Oct 23, 2009 at 1:47 PM
    aktarus
    aktarus [OP] Member
    [quote = chris4x4; 1.054.368] I belive il limitatore di velocità può essere aumentata con un programmatore aftermarket, ma non mi è sicuri di ciò che si fa presente. Tuttavia, è necessario che questo re, in quanto si tratta di un camion, e non progettate per alte velocità. La maggior parte dei pneumatici per autocarri sono solo nominale a 115 km / h, o inferiore. [/ Quote]
    thanks,
    could you point out where I can find photo and explanations of the inside commands of the dashboard as buttons, tools and other?
    thanks
  6. Oct 23, 2009 at 1:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Best bet would be the owners manual. If you dont have one, go to a dealer, and ask if you can look thru one.
  7. Oct 23, 2009 at 1:53 PM
    aktarus
    aktarus [OP] Member
    ignorance but in italia the tacoma they don't even know thing both...!!!!
    on line you think a manual can be found?
    thanks
  8. Oct 23, 2009 at 2:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can try here:
    http://www.toyotaownersonline.com/
  9. Oct 23, 2009 at 3:08 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Posso parlare italiano un po' - Qual'e il problema? Ho pensato che hai il hilux in italia, e non c'e il tacoma.
  10. Oct 23, 2009 at 3:24 PM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    I believe that something is lost in translation here. ====nominale a 115 miles not kilometers. This equal to about 170 km/hour. pretty fast for a truck.At this speed I guarantee you that, you will suck that gas tank pretty quick and with your gas prices????? you sure you don't want a Ferrari???.
  11. Oct 23, 2009 at 3:28 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW from Nevada, USA.:proposetoast:
  12. Oct 24, 2009 at 12:19 AM
    aktarus
    aktarus [OP] Member
    ciao
    io sto ordinando un Tacoma in USA,
    volevo conoscere le prestazioni se sono limitate. visto che devo ordinare il Tacoma, e ho visto alcune foto con diversi pulsanti alla sinistra del volante, volevo sapere le funzioni, di quei pulsanti.
    grazietante!!!
    Aktar us
  13. Oct 24, 2009 at 12:25 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    :confused:
  14. Oct 24, 2009 at 12:54 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    hello I am ordering a Tacoma in USA, I wanted to know the performances if they are limited. since I must order the Tacoma, and have seen some photos with various push-buttons to the left of flying, I wanted to know the functions, of those push-buttons. grazietante! Aktar us
  15. Oct 24, 2009 at 8:45 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    His message in English:
    I am ordering a tacoma in the united states, I was wanting to know the performance limits. I see that I have to order the Tacoma, and I saw another photo with different buttons to the left of the steering wheel, I was wanting to know what these buttons do. Thanks a lot! Aktar us
    Me in Italian:
    Possiamo discutere nel messagio privato o posso scrivere nelle due, moderatore?
    Capisco adesso! Vai avere un tacoma con il V-6 o I-4? Il V-6 puo accelerare da 0 a 96.5kph in 6 o 7 secondi. La massima velocita e 193kph, e ha 236 cavalli e 361N-m di forza rotatoria. Puoi anche comprare il compressore centrifugo (supercharger?) per piu accelerazione e riprogrammare il computer nella macchina per piu velocita.
    Sono incerto si il compressore centrifugo e la cosa che volevo dire. Dico di il 'supercharger'; e come un turbocompressore ma la potenza viene del motore e non viene del scappamento. Quando parlavo italiano con mia nonna, non parliamo dell macchine. :D
    I pulsanti sono diversi con i diversi modelli. Tipicamente, uno puo chiudere il VSC, il controllo di stabilita della macchina e anche, se lo teni, Auto LSD o... automatico differenziale di limitato scivolata? Funzione come un normale LSD, ma non e veramente un LSD, e completamente il computer che usa i freni. C'e un pulsanto per le antinebbie. C'e un pulsanto per RSCA off, che chiude i air bag di lata tenda, perche questi air bag puo spiegare inavvertitamente nelle fuori strade. Se hai un manuale, anche c'e un stretta-inizio-cancellare pulsanto, che ti permette di mettere in moto la macchina senza la stretta permuta.
    Me in English:
    We can take this to PM or post my response both ways, mod?
    I understand now! You're going to have a tacoma with the v6 or i4? The v6 can accelerate from 0 to 96.5kph (60mph) in 6 or 7 seconds. The top speed is 193kph (120mph) and it has 236 horsepower and 361n-m of torque (266 lb-ft). You can also buy a (i think that's supercharger) for more acceleration and reprogram the computer in the car for more speed.
    I'm not sure 'il compressore centrifugo' is what I wanted to say. I was talking about a 'supercharger'; it's like a turbocharger but the power comes from the engine and not the exhaust. When I was speaking in italian with my grandma, we didn't talk about cars. :D Apparently the italian word for 'forced induction' is literally 'overeating', which I find hilarious.
    The buttons are different with the different models. Typically, one can turn off VSC, the vehicle stability control, and also, if you hold it, Auto LSD o... automatic limited slip differential. It works like a normal LSD, but it isn't really an LSD, it is completely the computer using the brakes. There is a button for the foglights. There is a button for RSCA off, that turns off the side curtain air bags, because these air bags can go off accidentally offroad. If you have a manual transmission, there's also a clutch-start-cancel switch, that let's you start the vehicle without the clutch pressed in.
  16. Oct 24, 2009 at 3:14 PM
    aktarus
    aktarus [OP] Member
    [quote = SecretSquirrel; 1056061] Ciao Aktarus. Benvenuto a TacomaWorld.
    Tutto Che Jim (Jspadaro) dadi e coretto. Avete Bisogno di andare più veloce di 105 in autostrada il? [/ Quote]
    hi
    on the Italian roads the limit is of 130 km/hs,
    but to be possible to go faster!!
