Limited Service Campaign for Corrosive Resistant Compound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdvailco, May 20, 2014.
  1. Jun 27, 2014 at 12:18 PM
    #281
    toyohtadude
    toyohtadude Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    You can choose to wait until the last minute and see if perforation exists then. Just make sure you DO comply before the deadline and get it done or you'll have zero recourse for ignoring it.
    I was told there would never be any buyback beyond the '95-2000 model recall. It was either coating or replacement frames going forward. I'd LOVE 150% of NADA... That would be $35k for me but that'll never happen.
    I guess it's your choice, but don't forget and then miss out altogether!
  2. Jun 27, 2014 at 12:26 PM
    #282
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    better then a frame in a tacoma every 50,000 miles
  3. Jun 27, 2014 at 12:43 PM
    #283
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    I've always had good luck with Ford trucks. Ford cars is another case but ford trucks are excellent. that being said, I buy trucks to use as a truck. I know some people buy them because they like the look... That I don't know about but ford trucks used as work horses are very good. Better than toyota I'd say.
  4. Jun 28, 2014 at 4:11 AM
    #284
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    Mix up a load of brine and spray the inside of the frame every few days to save time. ;):D
  5. Jun 30, 2014 at 8:59 AM
    #285
    COoffRD
    COoffRD ShouldaKeptTheOldOne
    Val
    Vermont
    '05 Taco, 6sp
    Spintly,
    I'm up in VT w/ an '05 dbl cab w/ 107K. I've been approved for a new frame (they said they will get me in in 6 weeks or so) and that if I want a lift or anything installed while they're in there to just have it ready for them. It will be a nominal fee for labor, but no charge for stuff like an alignment that they have to do anyways.
  6. Jun 30, 2014 at 10:17 AM
    #286
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    Was thinking.... Don't ships have a block of sacrificial zinc bolted to their outside hauls to prevent rust? LOL, lets all do that!
  7. Jun 30, 2014 at 11:46 AM
    #287
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    water conducts
    air does not
    will not work and neither do the electronic systems that say they do. total sham. again they only work with conductive material surrounding the object.
  8. Jun 30, 2014 at 12:14 PM
    #288
    vram74
    05 Prerunner SR5
    Well shit! :p
  9. Jun 30, 2014 at 12:46 PM
    #289
    XXXX
    sKiP
    05 Prius
    I just spent the past 3 weekends under my truck fixing Toyotas mistake - so yea I looked into everything I could to stop this POS frame from eating itself to bits.
  10. Jun 30, 2014 at 2:54 PM
    #290
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Toyota of Portsmouth. Service manager actually called me the other day to schedule my appointment. October 6th or something. Again I mentioned I had already coated it inside and out and that it was covered with fluid film too. They said they would double check with their body shop but that it shouldn't be a problem. Guess it'll be a while before I put a set of Bilsteins in it....
  11. Jun 30, 2014 at 6:06 PM
    #291
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I would be grateful if you tell us what the Dealers responds back with concerning Fluid Film. I want to take my later model Taco in for Fluid film coating in the next couple weeks ...
    Thanks and good luck with your inspection
  12. Jun 30, 2014 at 9:32 PM
    #292
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Yes, the Tacoma has been a disappointment, a great looking truck!!, no doubt about it!, I have an "09" with under 30k, and the frame looks like it was used as a boat anchor, I was hoping to keep this truck for the long haul, but just might get rid of it, I really like the Tacoma but I think I will look at the Nissan Titan, (not sure what problems they have) jmop
  13. Jul 3, 2014 at 5:37 AM
    #293
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    Bristol Toyota in Bristol, RI replaced the frame on my '05 DC 2 week ago. I brought it to them in May for the seat belt recall and dropped a 2"X 3" piece of the frame on the service desk and asked for an frame inspection. There was a perforation near the drivers side cat.
    It took two weeks for the frame to come in and 3 days for the replacement. They gave me a Corolla to use.
    When I got it back, it had a new frame, new LCA's and ball joints, new rear leafs, rear wiring harness and brake lines.
    More details in this thread: http://www.tacomaworld.com/forum/2n...fficial-perforated-rusted-through-frames.html
  14. Jul 3, 2014 at 5:40 AM
    #294
    COoffRD
    Val
    Vermont
    '05 Taco, 6sp
    Did the new leafs change your rear height at all? Is it the 4-pack instead of the 3? My '05 DC is going in next month.
  15. Jul 3, 2014 at 10:47 AM
    #295
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
  16. Jul 4, 2014 at 5:10 AM
    #296
    oly51
    Gary
    S.E. MA
    The new 4 leafs did slightly change the ride height. Firmer ride and noticeable difference when towing my car trailer. Mine is the TRD Sport AC w/tow.
  17. Jul 4, 2014 at 9:02 PM
    #297
    COoffRD
    Val
    Vermont
    '05 Taco, 6sp
    Is anyone who's getting a new frame looking into replacing the hitch assembly? I'm guessing yours all look as crappy as mine (despite the sanding and painting last summer)! From what I've seen online it looks under $200; I'll have to ask Toyota about price on OEM, too.
  18. Jul 5, 2014 at 6:41 AM
    #298
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I would argue that since the hitch assembly holds on the rear bumper that it is part of the frame. Mine is a rusted mess. I have confirmed that my truck is on the LSC list. Unfortunately/ maybe fortunately Wisconsin is in the third group of states that will have this done.
  19. Jul 5, 2014 at 8:11 AM
    #299
    vjherrera
    vjherrera Well-Known Member
    Vince
    Chicopee,MA
    I talked to the dealer about this and was told that since the hitch is an option and not a required item it is not covered....mine is so gone that I wont tow with it and will wait till my appointment on the 29th of sept to see what happens
  20. Jul 5, 2014 at 1:48 PM
    #300
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    At least your on the list robssol, Iowa is not included in the approved "cold weather states".
    I only live 2 miles from WI as the crow flies, can see Wyalusing State Park from my back yard, do a lot of driving in the PdC area, work in your state and even pay WI income tax. Must be something with The River!
