Limited Service Campaign for Corrosive Resistant Compound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdvailco, May 20, 2014.
  1. Mar 26, 2015 at 11:55 AM
    #1181
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Just haul gravel with the loaner Prius they'll give you.
  2. Mar 26, 2015 at 4:36 PM
    #1182
    Aloe
    Aloe Well-Known Member
    05 SWB TRD Sport access cab 4x4
    URD Short throw Fisher Plow
    Are those your old leafs on the new frame?
    I saw some rot on my front can mounts too.
  3. Mar 29, 2015 at 9:12 AM
    #1183
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Hey Liberator.
    What parts other than the frame did they use for the swap?
  4. Mar 29, 2015 at 11:32 AM
    #1184
    unskinator
    unskinator Active Member
    Unski
    Delaware
    05 4x4 V6 accesscab 6 on the stick sports
    I just got my 05 back from the dealer. They picked it up from my house and brought it back on friday. Whole frame and rear springs were replaced. also front lower control arms and just about everything else underneath. List was long. All at no cost to me. Mine had excessive rust including holes due to rust. Dealer was very helpful and professional. I had received the letter in the mail just like you. Refused the loaner they had offered as i had no need for it. Good service from Toyota.
  5. Mar 29, 2015 at 1:13 PM
    #1185
    unskinator
    Unski
    Delaware
    I attached couple of pics of the frame on my 05. It was replaced under the recall.
  6. Mar 30, 2015 at 6:50 AM
    #1186
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Wow , that one is awesome - they should be proud of the build quality at Dana ....
    Sarge
  7. Mar 30, 2015 at 3:56 PM
    #1187
    thor92
    thor92 Member
    Right Coast
    07 TRD Sport SR5
    Took mine in for the inspection today. It passed, and they want to spray it with the CRC.
    Thing is, I've had it up on my lift and can see where there's significant rust on the middle section of the frame where the two pieces are sandwiched together, as well as the beginning of the holes up by the cats on the left and right side (its already a few layers in, but passed the hammer test).
    After reading here and a few other places, I'm pretty apprehensive about having the CRC done. I had an undercoat job done when I bought it (free from the dealership), and it doesn't seem to have helped. I'm also skeptical that they'll do the prep work to remove the existing coat before spraying the CRC all over the place.
    So, that has me wondering:
    1)Has anyone had any luck in either convincing them to replace the frame, taking it to another dealer for a second opinion, or contacting Toyota directly?
    2)For those that have had the CRC applied, is there anyone that's actually satisfied with the way it turned out (did it dry, did they do a thorough job, etc.)
    3)What happens if I simply blow off getting it sprayed by the dealer?
    If they're not going to replace the frame, I feel that I can do a better and more thorough job of restoring and coating the frame with better stuff than they can even if it's coming out of my pocket. In the end all I care about is that this truck isn't going to rust out and that it'll last a long time.
  8. Mar 30, 2015 at 4:12 PM
    #1188
    jliberatore92
    jliberatore92 Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    Just got it back today. Pretty happy with the results. Didn't have to pay a dime. Also replaced my lower control arms.
  9. Mar 31, 2015 at 3:45 AM
    #1189
    Mike550
    Mike550 Member
    Michael
    Cherry Hill, NJ
    SR5
    Pro Comp 7036 17X9 BFG Rugged Terrain 265/70/17
    Interesting that there are multiple ways the frames are being replaced. My truck was dismantled with the engine kept in the cab by the use of a jig. Others are being removed after the cab is lifted off the frame...
  10. Mar 31, 2015 at 4:16 AM
    #1190
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    Funny you mention that. I wanted to have them replace the water pump, t stat, idlers, tensioner and belt. I figured they would cut me a deal since they had the engine out. They said they would not pull the engine, left it in the truck. I was wondering if they were full of it but now I guess they were not. They quoted me $600 labor for all. They said they use an engine brace to hold it to the body.
  11. Mar 31, 2015 at 9:14 AM
    #1191
    spaul302
    spaul302 New Member
    Central Pennsylvania
    07 Taco
    My outcome from CRC application,also scratched truck pulling off bed.:mad:
  12. Mar 31, 2015 at 4:22 PM
    #1192
    unskinator
    Unski
    Delaware
    Looks like yours wasnt as bad as mine.(see pics couple of notes above). Mine they also replaced control arms and rear leafs plus an long list of other stuff, all paid for by Toyota. This keeps me still a Toyota person, they do stand behind their product.
  13. Apr 1, 2015 at 4:39 AM
    #1193
    Mike550
    Mike550 Member
    Michael
    Cherry Hill, NJ
    SR5
    A pic of the engine jig.
  14. Apr 1, 2015 at 5:28 AM
    #1194
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Do they clean up the engines prior to re assembly?
    If I was brining mine in for a frame swap I'd definitely the engine/engine compartment cleaned and pressure washed.
    - Better for the Tech
    - Looks better when done
    - Easier to inspect when completed.
  15. Apr 1, 2015 at 8:30 PM
    #1195
    81shark
    81shark Well-Known Member
    looks like something that shop put together. i could be wrong.
  16. Apr 1, 2015 at 8:48 PM
    #1196
    81shark
    3-4 weeks quickly has turned to the middle of week 6.
    which isn't a bad thing, considering i plan on doing some sort of road trip next week.
    downside is instead of going to the dealer every 5 months or so for an oil change, i have to go ever couple of weeks for something. plates expire at the end of the month. uhg
  17. Apr 2, 2015 at 1:05 AM
    #1197
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I for one am extremely happy that the CRC is not designed to dry. Rubber compounds that dry eventually crack, allow moisture in behind, trap that moisture and make corrosion even worse. It eventually flakes off and looks like crap. Don't ever let anyone tell you otherwise. Any compound that doesn't dry, is oily in texture will work its way into things and provide better protection. Anything that dries is a bandaid. Plus it is impossible to get every square inch, so a product that isn't oil will simply land where it's sprayed. An oil product has mist and can at least leave a fine layer on very hard to reach areas.
    For those worried about working on vehicles. Yes you will get your hands dirty but I'd rather go wash my hands and tools after getting the job done quicker and not fighting with seized bolts. To the above poster, saying you won't be able to service your frame? Wire brush or scrapers work well.
    Yes dirt does stick to it but it really isn't that bad, I don't have an issue on my truck and I run back roads/trails to go fishing, hunting etc. The underneath of my truck is wet all year from the oil.
    As for the overspray, I agree they should be cleaning your windows, handles etc. Having done my own undercoating for years let me tell you it's impossible to avoid. It even gets on the roof and I do it outside. Do you really expect them to tape off the body like they are prepping for a paint job? Common... lol. The smell? That's gonna happen, they are spraying stuff on your vehicle. Mine stinks for a few days too. I usually take it for a ride and it leaves a cloud of smoke behind from the oil burning off.
    I have been spraying vehicles myself for years. I have tried numerous products from motor oil, transmission fluid, products such as fluid film but now have settled on a dripless gel like oil undercoating. I do it myself every fall. From the pics it seems like this product is similar. You shouldn't worry about getting this stuff put on. I spray it on everything. Maybe that's just me up north here where putting oil under your vehicle to make it last is common practice.
    Glad to see Toyota owning up and actually doing something.
  18. Apr 2, 2015 at 4:53 AM
    #1198
    myrustytaco
    myrustytaco Active Member
    Jerry
    Michigan
    06 tacoma
    Debadged 18" wheels
    Still waiting on a wiring harness, frame is in. Two weeks ago they tried to tell me Toyota doesn't replace them as part of the recall now. Really tired of all the BS surrounding this recall and the lack of support from Toyotacares helpline. Just fix my truck as promised in the beginning of the recall and let me be on my way. This is my first and last Toyota because of the pitiful way this recall has been handled.
  19. Apr 2, 2015 at 4:56 AM
    #1199
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    It's not a recall
  20. Apr 2, 2015 at 2:48 PM
    #1200
    spaul302
    spaul302 New Member
    07 Taco
    I for one am not upset with Toyota corp. It's the dealer I took mine to scratch my truck up and can't admit they did anything wrong.
