Limited Service Campaign for Corrosive Resistant Compound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdvailco, May 20, 2014.
  1. Mar 25, 2016 at 2:03 PM
    #1361
    FilthyOx
    FilthyOx Member
    Northern Vermont
    06 yota
    CBI Sliders, 265/75/16, PIAA Fogs
    No I completely agree and the time to get the loaner was way to long. I have a commuter car luckily so I wasn't driving the uninspected truck at the time. If I was I would have been calling daily for a loaner. I let them off easy honestly.
  2. Mar 26, 2016 at 10:50 AM
    #1362
    Markcal
    Markcal Well-Known Member
    Did you get that in writing, because I haven't heard anyone from the USA, getting a warranty for 15 years?
  3. Mar 26, 2016 at 2:21 PM
    #1363
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I've seen others on site that have mentioned the same. I believe that's what made me press the issue.
    Nothing in writing yet Robert my claims guy will be in touch with me Toyota care told me this when I called it was after hrs.
    But this is the third time I've called and asked the result of my claim and have got the same answer.
    I don't give them any info other than claim and name.
    We shall see. If I thought is was not covered it would be gone. Buddy's tundra failed state inspection 2 yrs after the crc job. Toyota patched it?
    The crc is no fix.
  4. Mar 27, 2016 at 5:13 PM
    #1364
    betipper
    betipper Active Member
    London Ontario Canada
    Toyota Tacoma TRD Sport LB
    Modified grill, fogs lights behind grill, leer cap, redline leather goods, hid headlights, hood lights,undercoated and oiled, beep for lock mod, fog light on mod, box lights, reverse brighter mod. bulbs, bed mats, weather tech liners, iPod interface, ome leaf pack, spacers front suspension, diff drop, drive shaft drop,
    Does anybody have the procedures they are supposed to do when they do the crc rust product , what they are to spray and scrape and what they are to remove from the truck before they do it. Thanks.
    I had mine done I can flick chunks of rust of the frame that has been coated. The engine frame mounts have not been sprayed or cleaned.
    I need the procedures they are to do.
    Thanks.
    Bump
  5. Mar 27, 2016 at 6:08 PM
    #1365
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    When mine was done, I was told by the dealer they would remove the box and wire wheel all offensive spots/ cleaning the rest. They also said it would be 2-3 days. And would inspect again before coating.
    This was at the beginning of the campaign.
    Went in 7/15 box was not removed, not sure if it was even cleaned. I kept it clean and coated
    since I got it in 2011.
    Returned to me that same day.
    Dripped for another 3 days.
    Not sure what is supposed to get coated and what does not?
    The guy who did mine tried I give him that.
    The top of frame under the bed was not coated, one of the coils was the other not etc. But you can only do so much without covering everything in it and in that time.
    I belive the dealership was using a sub contractor to do the work, others must be doing the same?
  6. Mar 27, 2016 at 6:13 PM
    #1366
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I don't know the procedure for that particular product but it appears to be a waxy self healing protectant/sealer and not a rust neutralizer. Therefore the proper procedure would always start with "remove all loose rust and scale". That would require mechanical abrasion (media blast, grinding, sanding, wire wheel, etc) followed by application of phosphoric acid.
  7. Mar 28, 2016 at 2:24 PM
    #1367
    betipper
    My was done with in 3 hours. They had the truck for 2 days I work across from where the sub contract them to be done. They hold me when I first went in the the rear bumper and spare tire had to be removed. There is no way they removed the rear bumper. Where your front engine mounts coated. There for sure was no rust removal on the frame I can pick off chucks of rust that are coated. Rust has leached through the coating. Not happy. I am sure they did not even wash the salt of the frame before coating. They did not have it long enough for it to dry before coating.
  8. Mar 30, 2016 at 7:42 AM
    #1368
    caberg
    caberg New Member
    Vermont
    Got the call on Monday that the frame kit has been ordered. Now the waiting game begins.
  9. Feb 9, 2017 at 6:22 AM
    #1369
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    Has anyone heard or gotten any new information about the class action lawsuit other than the little post card they sent out a couple of weeks ago?
  10. Mar 5, 2017 at 6:19 PM
    #1370
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    Search TW for "Toyota Frame Settlement Postcard"
    For details regarding a Class Action lawsuit in progress early 2017:
    http://www.toyotaframesettlement.com/
    Brian Warner et al. v. Toyota Motor Sales, U.S.A., Inc., Class Action Settlement.
    For help, you can call the lawyers representing the class at 619-338-1100.
    Pending Lawsuit covers Toyota Model Years:
    Tacoma 2005–2010
    Tundra 2007–2008
    Sequoia 2005–2008
    N919HJ likes this.
  11. Mar 6, 2017 at 1:14 PM
    #1371
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    got my postcard today
  12. Nov 13, 2018 at 4:26 PM
    #1372
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Hey, heads up January 31st 2019 is the extended deadline for this campaign.
    Check with your dealer for 2005-2010 Tacomas.
    "The coverage offers the latter of 12 years from the Date of First Use (DOFU) or January 31, 2019"
    Just got my 05 Sequoia done and the CRC looks really effective, a gooey tar like coating, relieving my worries of salt corrosion. (My Sequoia was from Maryland and frame was pretty nice still)
  13. Nov 15, 2018 at 2:52 AM
    #1373
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Don’t kid yourself. The CRC is junk! Had my Tacoma done 2 years ago, it flaked of in 6-8 months and ended with a frame swap last spring.
    Lesson: Keep a eye on it!
    DLillest likes this.
  14. Nov 15, 2018 at 7:26 AM
    #1374
    KTM753
    KTM753 Well-Known Member
    So my 2010 is covered until 2022 but a 2005 would need to be inspected by the new January 3, 2019 deadline correct?
  15. Nov 15, 2018 at 8:28 AM
    #1375
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Sounds that way.
  16. Nov 15, 2018 at 8:55 AM
    #1376
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I got a letter this week telling me that the frame warranty extended to 10 years from DOFU or 1/31/2019. My frame has already been inspected and treated with CRC earlier this year (2018). I'll make sure to get the frame inspected every year until the warranty expires in 2022.
  17. Nov 15, 2018 at 11:32 AM
    #1377
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    Agreed with other posters. My frame was coated in 2016, and in less than a year there was nothing left of the CRC, just flaking rust.
    Definitely keep an eye on it.
  18. Nov 15, 2018 at 6:17 PM
    #1378
    ARCHIVE
    Eric
    Was your coating like a rust converter that was dry to touch? I have seen frames coated with that and I agree it looked poor and not durable. I'll try to get a picture and post this gooey stufff
  19. Nov 16, 2018 at 3:53 AM
    #1379
    DLillest
    Quebec, Canada
    From what I can remember it had almost a rubbery texture. There isn't much left of it now. I'm just waiting on my frame replacement.
  20. Nov 16, 2018 at 6:08 AM
    #1380
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Anyone recently here have there frame replaced? If so how long did it take for Toyota to approve your new frame?
    Just had the dealer last week look at the frame and found a hole, still waiting to hear back from them about the approval.
