Limited Slip Differential, does my truck have this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, May 7, 2012.
  1. May 7, 2012 at 4:13 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I have an '08 Prerunner 4.0 V6 Double Cab. How can I know if it has Limited Slip? I assume that I don't have the Locker Diff, Right?
  2. May 7, 2012 at 4:17 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Is it sport? Look at the axle for a lsd oil only sticker.
  3. May 7, 2012 at 4:18 PM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    If you have an offroad, you have the locker. I think everything else has the lsd. Turn off traction control and see if auto LSD comes on.
  4. May 7, 2012 at 4:18 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Wont be auto on a 08
  5. May 7, 2012 at 4:20 PM
    757 Taco
    Tyler
    757
    Oh my bad :eek:
  6. May 7, 2012 at 4:21 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    No worries. You should read some of the shit i type lol
  7. May 7, 2012 at 4:27 PM
    757 Taco
    Tyler
    757
    Coming from a 1st gen (tacoman355) so still learning. Love the truck though man. Looks real clean :thumbsup:
  8. May 7, 2012 at 4:30 PM
    mike1025
    mike1025 Well-Known Member
    mike
    Oceanside, Ca
    08 DCLB 4x4 SR5
    Firestone ride-rites airbag, bed speakers, bull bar and 14" light bar
    Some double cab longbeds SR5's from 05-08 came with the mechanical LSD. Check for the sticker on the diff housing.
  9. May 7, 2012 at 4:31 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Thanks:D
  10. May 7, 2012 at 4:37 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    My truck does not have any traction control buttons at all.
    Its an SR5 PRERUNNER (not a TRD). If that helps.
  11. May 7, 2012 at 5:04 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    If your diff doesn't have this sticker, then you don't have the LS.
  12. May 7, 2012 at 6:17 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    X1000 on checking for the sticker (link in my sig too). Most of the SR5 packages that had the LSD were on DC LBs. But Toyota did offer it as a separate option on other cab configs too.
  13. May 8, 2012 at 5:41 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Well, what if the sticker was removed or has fallen off? ;)
    I would still start by looking for this sticker, but you could also run your vin # at the dealer to be sure.
  14. May 8, 2012 at 6:29 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Pressure washer hasnt taken mine off... cleaned it a few times too;)
