Limited Slip Differential (LSD)
Discussion in 'Technical Chat' started by sdupp, Apr 24, 2011.
  1. Apr 24, 2011 at 10:31 AM
    sdupp
    sdupp [OP] SC Member
    SC
    White 07 PreRunner Double Cab SR5
    2007 Double cab PreRunner Automatic Trans. with Limited Slip Differential. At 40k the LSD was making all kinds of scrubbing type sounds and slipping on dry pavement. The Dealer replaced the entire Differential inside the pumpkin and all was good for a while. Now at 55k the same thing is happening again. Was wondering if anyone else has had this problem? Also do you think the Dealer could replace it with a regular Differential instead of the LSD. I really don’t want or need the LSD…..
    Thanks! Stan
  2. Apr 24, 2011 at 10:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Fluid change-Damn you Lurry.
    Yeah...Check the fluid. You can put whatever kind of diff in there you'd like...but you paid for an LSD.
  3. Apr 24, 2011 at 10:35 AM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    if anything ask for a locker, better to have it than need it later on down the road
  4. Apr 24, 2011 at 5:42 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    There you go, pushing a non-Toyota product again! ;)
    (just kidding with you Larry)
  5. May 1, 2011 at 6:01 AM
    sdupp
    SC
    I assume a Locker is a Non LSD is this correct? The last time I had this problem the dealer changed the fluid and did not solve the problem so they replaced the differential. I am at the end of the power train warranty and I really don’t care that I paid extra for a LSD, I just want the problem to go away so it doesn’t cost me money when the warranty expires.
    Thanks again for help
    Much Appreciated!
  6. May 1, 2011 at 6:18 AM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
  7. May 2, 2011 at 10:57 AM
    David K
    A locker is a 'no slip' differential when activated.
  8. May 22, 2011 at 6:15 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  9. May 22, 2011 at 6:23 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Did it have the LSD additive already in it or did you add a tube?? Some folks have found they have had some issues with synth fluids so you have to swap it again.
  10. May 22, 2011 at 6:24 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I've read the bottle over, I figured the fact it met the American Petroleum Institute (API) GL-5 standard it was already premixed and i was good to go.
    I'm going to have to change it aren't i....
  11. May 22, 2011 at 6:31 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think the GL designations cover more the type of actual gears (hypoid, sprial, etc) in relation to their loading/speeds.
    There are gear oils out there that are GL4/5 w/ LSD additive in it or separate tubes of LSD additive. I used Lucas gear oil with a separate additive.
    Check the bottle, then add the LSD additive if it's not there, then think about changing it.
  12. May 22, 2011 at 6:34 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    So the LSD additive, thats like a fluid? Gel? Will I have to drain some of the current fluids to put it in??
  13. May 22, 2011 at 6:36 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think it was like a fluid...but I didn't really pay attention..It's a small tube (like 4ozs IIRC) so you shouldn't need to. Might get a little dribble out of the fill hole...but no big deal
  14. May 22, 2011 at 6:37 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    K k, I will try this first n let ya know, Thx brunes!
  15. May 22, 2011 at 6:38 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No worries-I hope it works!!!
