Limited Slip Differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doctor John, May 2, 2010.
  1. May 2, 2010 at 10:39 PM
    Doctor John
    Doctor John [OP] Member
    Knoxville, TN
    2005 Tacoma
    Are either or both of the differentials (front and rear) in my 2005 4WD Tacoma considered to be "limited slip differentials?" What actually makes it a limited slip and why does this affect the choice of lubricant? Thanks
  2. May 2, 2010 at 10:41 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Do you have the Sport model/package?
    BassAckwards likes this.
  3. May 2, 2010 at 10:59 PM
    Doctor John
    Knoxville, TN
    2005 Tacoma
    I'm not sure. Can you tell me where to look to find out? I looked in my manual and didn't see anything specific about this.
  4. May 2, 2010 at 11:02 PM
    Mxpatriot
    Do you have "TRD Sport" decals on the side of the bed?
    Is your hood scooped?
    Do your bumpers and door handles match the paint of your truck?
    If yes - then you have a sport. And if it's an '05 as indicated in your profile, then you have a true LSD.
  5. May 2, 2010 at 11:05 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Even if the truck is just an SR5, the LSD could have been optioned into it, as was the case with my truck. Look at the rear differential, if there is a sticker on it that reads something like "LSD oil only" then you obviously have the LSD in there. Or if you have the original window sticker from when it was new, it will show the options added to the truck. If all else fails, give the dealer your VIN# and they can tell you.
    The reason for the LSD additive in the oil is as a friction modifier as the design of the Tacoma LSD is that of clutches that create a counter force helping the tire with less traction slip less and find traction.
  6. May 3, 2010 at 6:52 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yeah, most of the '05 SR5 packages had the LSD as part of the package. I had the SR5 package #8 and it came as part of the SR5 package. In fact, most of the SR5's sold around here had it! Now if you had a TRD Sport, then it's a given that you have it. The advice highlighted above is your best bet for figuring it out. That sticker will still be there, so don't worry about the possibility of it having come off over time.
  7. May 3, 2010 at 7:42 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Your front is open unless you have a locker or Atrac. Both of these will have buttons to either engage or disengage.
  8. May 3, 2010 at 7:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you have the LSD (mechanical) in the rear - you need friction modifier in the oil for the LSD to work properly. There are clutch paks in the diff and without the friction modifier, the rear will be 'grabby' and not function properly (hard to explain).
  9. May 3, 2010 at 9:09 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If you get the truck stuck in the mud or sand .... does just one tire (in back) spin, neither, or both?
    GoLongJoe likes this.
  10. May 3, 2010 at 9:11 AM
    David K
    A-TRAC was available in Tacomas starting in 2009. No 'factory' locker was offered for the front.
  11. May 4, 2010 at 5:40 AM
    Doctor John
    Knoxville, TN
    2005 Tacoma
    The decal on the side of the bed says TRD OFF ROAD Toyota Racing Development. The other body labeling says V6 SR5. The paint and bumper color is silver but the door handles are black. I don't think the hood is scooped. There is no LSD sticked on the rear differential. The description on the sticker is "6 speed manual transmission,4W demand 4x4 system w/ electronically controlled 2 speed transfer case."
  12. May 4, 2010 at 5:51 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Correct so he has an open front diff!
  13. May 4, 2010 at 6:56 AM
    05Moose
    Jim
    Sounds like you don't have a limited-slip rear differential then because it doesn't have the sticker on the rear differential...and more importantly because it sounds like you have the TRD Off-Road package. That package comes with a locking rear differential which can't be combined with a mechanical limited-slip. To know for sure that you have the TRD Off-Road package (and that someone didn't just stick the sticker on your bed), you should have a button on the dash for the locker (and you will also have the temp/compass display overhead).
  14. May 4, 2010 at 6:59 AM
    David K
    Other than a manual tranny, you have the same truck I had last (2005 4WD Off Road Tacoma) which HAS an electronic switch activated locking rear differenial (NOT limited slip). Both differentials are 'open'.
    The rear locker only works in L4 (Low Range), come to a stop to engage. Info sticker on drivers door.... RR Diff light goes from flashing to solid when engaged.
  15. Oct 26, 2016 at 11:13 AM
    hueman562
    hueman562 Well-Known Member
    ken
    los angeles
    13 double cab LB 4x4
    Anybody run redline gear oil with the redline friction modifier. It says that there is already the friction modifier inside and doesn't need anymore, anybody have any opinions on this
  16. Oct 26, 2016 at 11:26 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    If it says it has it I would say you are okay. I used Valvoline gear oil (Limited Slip) and the friction modifier that dealer used.
  17. Oct 26, 2016 at 11:33 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  18. Oct 26, 2016 at 11:58 AM
    tranandya
    tranandya Well-Known Member
    Andy
    Orange County
    07 DCLB TRD SPORT
    5100 885x LR UCA 1.5AAL FIRESTONE RIDE-RITE w/DAYSTAR CRADLEs
    You dont have a LSD.
  19. Aug 28, 2018 at 6:13 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Google search brought me here, sorry.
    Is it possible that the sticker on the diff could come off, or that someone could possibly switch out an LSD for an open diff? I have an ‘05 Sport and got stuck in the snow recently with only 1 rear tire spinning. Is there ANY other way to tell what kind of diff I have back there? I’m starting to think that I need to just pull the whole thing apart and look inside.
  20. Aug 28, 2018 at 6:16 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Very real possibility that the clutch packs wore out, making the LSD not as effective. At least I think that's a thing :anonymous:
