Limited Slip FAIL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gtmiller1001, Apr 18, 2010.
  1. Jul 12, 2010 at 9:30 AM
    #161
    Ace83
    Ace83 Well-Known Member
    TX
    SR5
    Bilstein Front shocks, Rough Country 3" lift kit, 5" black railway running boards
    take vids next time you do this :)
  2. Jul 12, 2010 at 9:48 AM
    #162
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I'm sure you're a good guy but with antics like that we should all pitch in for a Cam at your home. I'm sure we could win video mishaps with ease!
  3. Jul 12, 2010 at 10:11 AM
    #163
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    To the OP: Your Doing it all wrong. Your not gonna get your LSD to work correctly that way. The LSD works in certain locations only. Do the exact same thing you did before, but this time put your car near the edge of a cliff. Should work like a charm.
  4. Jul 12, 2010 at 10:19 AM
    #164
    HBMurphy
    Paul
    So California Coast
    None
    Maybe the OP was trying lysergic acid diethylamide!
    http://www.youtube.com/watch?v=y9uYEM2osYQ
  5. Jul 12, 2010 at 10:29 AM
    #165
    JKD
    JKD Well-Known Member
    You sure about that? Check the engine RPM vs. speedometer.
    I (now) know that the taco uses the ABS/Traction sensors to compute vehicle speed, but does it really take a plain average of the sensor inputs?
    In conventional systems with the speedometer read from the transmission output shaft, a speedo reading of 60 mph with one drive wheel stationary would cause the rotating wheel to be going twice as fast.
  6. Jul 12, 2010 at 10:32 AM
    #166
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    LSD will only provide torque up to it's clutch rating, then it slips. It's somewhere around 100 lbs ft.
    Wheel on ground with one wheel spinning=smoking diff, open or LSD.
  7. Jul 12, 2010 at 3:56 PM
    #167
    Manwithoutaplan
    ID
    The darwin award ehhh
  8. Jul 12, 2010 at 3:57 PM
    #168
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I dont know why this is getting repeated but needs correction ....
    Factory LSD installed in 05-08 Tacomas works with wheel in the air.
    it will provide at best 150 foot-pound torque. Not a lot but still does.:D
  9. Jul 12, 2010 at 4:06 PM
    #169
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    darwin award!!!
  10. Jul 12, 2010 at 4:07 PM
    #170
    Manwithoutaplan
    ID
    BOOO ya!!!
  11. Jul 12, 2010 at 7:42 PM
    #171
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    You are lucky it didn't decide to engage at 60. Just because you were in an open area doesn't mean anything. At the very least you probably would have snapped an axle shaft
  12. Jul 12, 2010 at 8:06 PM
    #172
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As I mentioned before, X2. I have gone up hills with a tire in the air just fine.
  13. Jan 22, 2011 at 10:16 PM
    #173
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    For The Win!!!
  14. Jan 22, 2011 at 10:21 PM
    #174
    SargeSlapnuts
    Nick
    Pooler, Ga
    i have a 1994 doge dakota 4x4 with a 318v-8 in it and when it had a conventional diff i could get on the highway at 70mph in the rain and floor it and just one tire would spin. the i threw a mopar drag diff (lsd) in it and when i got on the highway at 70mph in the rain and floored it it would throw side way across three lane of road if i wanted it to. dont think your lsd is work or your just simply dont have one in your truck.
  15. Jan 23, 2011 at 8:50 AM
    #175
    lepedog23
    lepedog23 Taco Rookie
    Frank
    Huntington Park
    Wrecked 2002 4Runner 4x4 trying to rebuild ***Sold2001 DC Tacoma. Stock. Salvage Title MOD.
    Wrecked 2002 4Runner 4x4 ***Sold 2001 Tacoma, Salvage Title MOD. ***Sold 2010 Tacoma doublecab prerunner
    hahahahah do it...
    not to me though...
  16. Jan 23, 2011 at 9:14 AM
    #176
    michaelg589
    michaelg589 Well-Known Member
    I hate to repeat what everyone has already said. But, what you did was EXTREMELY foolish and dangerous. With that said.......
    Are you positive you even have a TRD Sport? There have been many trucks sold as TRD models when they were just base SR5s with TRD stickers.
  17. Jan 23, 2011 at 9:18 AM
    #177
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Let me guess...and you were doing this in your garage too...
    I think someone's looking over your shoulder...and I'm not religious either...
  18. Jan 23, 2011 at 9:27 AM
    #178
    BlueT
    NorthEast
    Factory one and TRD are two different limited slips. Just saying
  19. Feb 27, 2012 at 7:05 AM
    #179
    beckettisgod
    beckettisgod Well-Known Member
    Vermont
    '09 TRD Sport Barcelona Red
    Fog light anytime mod, Black lower valence, In-channel AVS Ventvisors, drop-in K&N filter so far...
    Question about TRD sport LSD : With the rear jacked up on stands and the truck in neutral, if I spin a wheel (by hand), the other should spin the same way, correct? Or does it need resistance?
  20. Feb 27, 2012 at 7:22 AM
    #180
    tranceporter
    tranceporter Well-Known Member
    Rishi
    Atlanta, GA
    4x4, DCSB, Off Road, V6 Tow
    totally made my monday morning.
