Limited Slip rear axel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cicada83, Feb 27, 2011.
  1. Feb 27, 2011 at 5:44 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I just have a quick question. I have an SR5 2008 4wd 5 speed 4cyl tacoma. I noticed the the passanger side rear wheel seems to be the powered wheel. I thought mine truck had a limited slip...am I wrong? If so is there a limited slip tacoma? Is there a way to make mine limited slip if its not? I'd like power to both wheels. Thanks for any input.
  2. Feb 27, 2011 at 6:23 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Detroit trutrac has one for tacomas , i want one too. SR5, if im not mistaken, is open diff , the TRD's get the traction of lsd or lockers.
  3. Feb 27, 2011 at 8:24 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Like Christian said, some of the SR5's came with an LSD. It just depended on the SR5 package. Take a look at the link in my sig to see what the LSD sticker looks like. That's the easiest way to tell if you have one.
  4. Feb 27, 2011 at 8:28 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    All 09' and up have an auto LSD vs the Mech. that was in the sports! The auto engages when u turn off the traction control (clicking the skidding car button) if I'm not mistaken!
  5. Feb 27, 2011 at 11:40 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    They have TWO levels of limited slip in 2WD...
    1) TRAC (with engine output regulation)
    2) AUTO LSD (no regulation)
    In 4WD-High: it is called 'TRAC', but it has no regulation, the same as AUTO LSD.
  6. Feb 28, 2011 at 7:08 AM
    05Moose
    Jim
    x2.
    But to fix your statement anyway...ALL '09+ Tacomas have auto LSD. It is a standard feature that has nothing to do with the TRD Sport anymore.
  7. Feb 28, 2011 at 8:18 AM
    David K
    Exactly why I QUOTED the one person's post (theduck911) I was responding to... :rolleyes:
