Limited Slip Rear Diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by diapsalmata, Feb 12, 2012.
  1. Feb 12, 2012 at 7:15 PM
    diapsalmata
    diapsalmata [OP] Member
    Ontario, Canada
    05 4x4 SR5 Access Cab
    Who's idea was it to sell ANY truck with an open differential? Generally there's no need for me to be in 4x4 during city driving in the winter. Then we get a couple inches of snow, and i'm the jackass with one tire spinning, trying to get out of the intersection and let people get to work on time.
    I'm no lead foot, but even for safety reasons a limited slip should be mandatory on pretty much any truck. If you accelerate suddenly while at cruising speed, the spinning tire tends to pull the truck towards it's side, sending you into drift-mode. Yet there's nowhere near as much control compared to having both wheels spinning in sync where you can correct with throttle or steering... :( My last Toyota pickup had a limited slip, last winter I drove it practically every day, almost always in 2wd, with next to no traction issues.
    What are my options here?
    Detroit True-Trac?
    Does Toyota make an OEM limited slip differential for '05 Tacomas?
  2. Feb 12, 2012 at 7:19 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    Try pulling the e-brake a bit as you are accelerating sometimes that slows the spin on the tire spinning and can send some traction to the non-spinning tire.
  3. Feb 12, 2012 at 7:21 PM
    badger
    badger Well-Known Member
    07 SR5
    my SR5 had it too before I put in the ARB
  4. Feb 12, 2012 at 7:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The Detroit Tru-Trac is a good unit. Less expensive than the TRD LS Diff.
