Limited slip, what are my options?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cicada83, Oct 1, 2011.
  1. Oct 1, 2011 at 6:42 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I have an 08 4x4 2.7 5 speed. It does not have a limited slip. What, if anything, can I do to convert to an LSD? Does it matter I have a 4x4? Thanks for any suggestions.
  2. Oct 2, 2011 at 11:05 AM
    cicada83
    Midland, MI
    Retro white SR5 4x4
  3. Oct 2, 2011 at 11:08 AM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    Search my friend, you will find your answers.
  4. Oct 2, 2011 at 11:10 AM
    InfidelTaco
    G
    PNW
    Prerunner
  5. Oct 2, 2011 at 11:11 AM
    TRDBandit
    TRDBandit TACOMANATOR
    Justin
    CRAWLORADO
    07 Dbl Cab TRD O.R. Dark Blue
    Afe Stage 2 CAI Tinted windows Many to come
    So You can add atrac to an 06 trd OR with Locking diff??:eek::D
  6. Oct 2, 2011 at 11:15 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    No... not without more time and money than installing ARB lockers, I am sure. Hydraulic brake booster, spin sensors, the ecu... wow, can't imagine!
  7. Oct 3, 2011 at 12:07 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    great suggestions. does anyone know though the 09' has a LSD is it a true mechanical one or is it computer controlled? also someone mentioned phantomgrip.com, would this product work?
  8. Oct 3, 2011 at 6:45 PM
    David K
    Not for you Christian, just extra details for newbies:
    ALSD is a setting with TRAC... TRAC is the electronic/ ABS brake assisted limited slip system and is short for 'TRACtion Control'. When you engage AUTO LSD, it is TRAC but without the engine output regulation.
    TRAC in 4WD is really the same as AUTO LSD, but Toyota calls it TRAC in H4, but there is no regulation.
  9. Oct 3, 2011 at 7:56 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Detroit True Trac differential or an Auburn diff could be a good upgrade as well.
