Limited slip??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ocean's, Oct 12, 2010.
  1. Oct 12, 2010 at 9:34 PM
    Ocean's
    Ocean's [OP] Well-Known Member
    I have a 2008 DC TRD Off Road. Just driving in 2 wheel drive, i thought that the power-tire would be the Right Rear, and that we DON't have a limited slip.
    However, When i was on the lawn, I spun the right wheel and then i see the left one spinning. I checked the lawn and yes there was a 3 foot burn out ont he right side and about 4 feet forward, another 3 foot burn out on the left side...??
    Confused...:confused:
  2. Oct 12, 2010 at 9:37 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    If I understand you both tires didn't have any traction so they both spun. Which would make sense.
  3. Oct 12, 2010 at 9:45 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    without the locker engage, you have a LSD, Thats what you are saying?
  4. Oct 12, 2010 at 10:23 PM
    Jefenator
    Jefenator Taco Truck Noob
    Oregon
    2010 2WD Reg Cab Stick Shift
    My rig has the "automatic limited-slip differential".
    According to the official blurb, it works by "selectively applying brakes to the wheel that slips and sending engine power to the wheel with grip".
    I haven't tested this, yet. Can anyone tell me how well it actually works? If I have one wheel on ice or deep gravel & the other on pavement, can I power myself uphill?
  5. Oct 12, 2010 at 10:27 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    ^In theory
    But Auto LSD I beleive only became standard in 09+. 05-08 TRD Sports have LSD, otherwise you have an open diff (with a locker if you have TRD offroad).
  6. Oct 12, 2010 at 10:41 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    sr5 has LSD as an option as well.
  7. Oct 12, 2010 at 10:43 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Yes, they are indeed limited. ;)
  8. Oct 12, 2010 at 10:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Nice knockers OP .
  9. Oct 13, 2010 at 12:27 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    He has an '08 OFF ROAD which means no limited slip in the differential (those were in the 'Sport' only). The 'electronic' limited slip system (Auto. LSD/ TRAC) didn't start until the '09s.
    He has a normal open differential with a LOCKING REAR differential that can be activated by button. If his Taco is a 4WD, then the RR Locker only works in Low Range.
    Because an open diff. will put torque to the tire with less traction, it can go to either left or right tire... whichever spins the easiest. If equal traction, torque goes to both rear tires equally.
    Whippersnapper gives some excellent info on why we USUALLY see the same rear tire spin in back, when we get stuck!
  10. Oct 13, 2010 at 12:47 AM
    David K
    The best way for you to know how well it works is to go some place in the dirt or snow and use it.
    The standard drive mode is with TRAC on, in 2WD. It is a 'lite' limited slip and does regulate engine output along with braking a spinning tire.
    BUT, do a quick push of the VSC OFF switch avatar7907_14_2dbf3432433974eeb60eb958d75d15d11c97c2f3.gif and that turns on 'AUTO LSD' which is a stronger 2WD limited slip than is TRAC as there is no engine regulation! This is like Posi Traction for your rear end for power take offs. It helps when one tire is off the road in slush.
    If tire spinning is desired, you can de-activate the limited slip system and just have open differential(s) by hold down the VSC OFF switch, while STOPPED for 3-5 seconds.
    If you have 4WD, the TRAC in High Range 4WD is actually like Auto LSD as there isn't any engine regulation. Toyota could have used better names or called TRAC in 4WD something different or AUTO LSD, maybe?
