Limited Slip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hopster, Nov 8, 2008.
  1. Nov 8, 2008 at 3:40 PM
    Hopster
    Hopster [OP] Member
    Chattanooga, TN
    06 PreRuner
    Anyone know the best way to make my 2 WD 06 Tacoma limited slip?
    Is it just a matter of ordering a part for my differential ? Or is there an aftermarket mod? Is is possible?
  2. Nov 8, 2008 at 3:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to Tacoma World! :)
    If your truck is not equiped with an LS diff already, then you would have to have one put in.
  3. Nov 8, 2008 at 3:59 PM
    Hopster
    Hopster [OP] Member
    Chattanooga, TN
    06 PreRuner
    What does that entail ? Just ordering a gear from toyota and putting it in my differential? Or is it more involved?
  4. Nov 8, 2008 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its more involved than that. Most LSD's replace the entire carrier and pinion gears, which means you have to separate the axels from the truck, pull the third member, then remove the open diff assembly, and reinstall the LSD assembly. Im over simplifing it, but if you have never done it before, its best done by someone who knows how to do it.
  5. Nov 8, 2008 at 4:48 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Welcome to TW Hopster..............I see you met chris, he's top notch. Many helpful and knowledgable people on here.:D
  6. Nov 8, 2008 at 5:19 PM
    Hopster
    Hopster [OP] Member
    Chattanooga, TN
    06 PreRuner
    thanks guys-- now to find someone around here that can do it.
  7. Nov 8, 2008 at 7:07 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    Detroit Truetrac LSD 913A541 $400-$550 plus installation $450-$550.
  8. Nov 8, 2008 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Very good Recomendation! BUT, the install shouldnt be that much.
  9. Nov 9, 2008 at 11:01 AM
    SteelCity
    Charleston, SC
    Every where I went it was. I found one shop that charges a flat $75 hour at approx 5-6 hours and two bearings are needed.:(
  10. Nov 9, 2008 at 11:07 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Try a junk yard, er.....ummmm, excuse me, a RECYCLING yard. See if you could get one that has a LS in it. Ask the guy if he'll take yours in trade with a little cash to add. If it's the same year(s) it should be an easy swap.
  11. Nov 9, 2008 at 11:43 AM
    wormhole7
    wormhole7 Well-Known Member
    Lake Dallas, Tx
    TSS
    Leather, Suspension TSB, Billy 5100's up front set at .85, Eaton Posi LSD,Grillcraft Black Mesh Grills,Aires Bull Bar,Black Low Profile Narrow Toybox,Black Headlight Mod,Black Tail lights ,USA Spec,Ipod, PopnLock,Bed Mat,Bug Sheild,Vent Visors, Weathertec Liners,Radar,Nuvi 760,Dog Ramp,Convex Mirrors, Roof Rack, Tint, Borla exhaust, Borla Intake, OBX pedals, Home Link Auto Dimming Mirror with remote, 20" Factory Wheels, Factory Tube Steps
    4wheelparts did mine for about 900.00 (parts and labor).
    That was for an Eaton LSD
  12. Nov 9, 2008 at 11:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On an LS diff, better to get new, as the friction plates may be worn out.
  13. Nov 9, 2008 at 7:49 PM
    Hopster
    Hopster [OP] Member
    Chattanooga, TN
    06 PreRuner
    Thanks for the info guys. It looks like the DET911A565 will do the trick-- looks expensive though.
  14. Nov 11, 2008 at 11:45 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    Will that fit an 08 prerunner? I've been looking for a truetrac for about a month now, and have so far been unsuccessful
  15. Nov 12, 2008 at 4:57 AM
    Hopster
    Hopster [OP] Member
    Chattanooga, TN
    06 PreRuner
    Actually if you go to Detroit's website they dont make one for the 2wd. The website that is selling them has the info in error. If you go to the Summit Racing website , they have the correct data.
    Looking for a rear end assembly, but everyone want $1000-$1200. I don't need anti slip that bad. If I could get one for 400-500, I would think about it.
  16. Nov 12, 2008 at 1:39 PM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Well, after googling "Detroit Truetrac LSD 913A541" The cheapest I found is 436.00 However, Its a 10 bolt assembly, and after crawling under my truck I found that mine has 12 :eek: I guess i'll have to wait to see if they'll make one that fits.
  17. Nov 12, 2008 at 2:16 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i was thinking about doing the same thing to my truck i was trying to split myself from the LSD or get the locker what do yall think
  18. Nov 12, 2008 at 2:30 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The (vendor?) listing that claimed it's a 10-bolt assembly must be wrong.
    Detroit lists the 913A541 for the '8.4' differential, which is a 12-bolt ...
  19. Nov 12, 2008 at 5:08 PM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Well, I just talked to the guys at www.differentials.com (west coast differentials) they found my part and with shipping its going to run
    me almost 500 even.
