Limited slip?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marc70, Dec 6, 2015.
  1. Dec 6, 2015 at 6:47 AM
    Marc70
    Marc70 [OP] Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    just bought a real decent '08 Tundra, reg 4wd. I'm wondering about adding a limited slip, if it's worth the money. It's my first 4wd, but second truck.
    I don't plan on going crazy 4wheeling, but do want to get out.
    Any thoughts or suggestions? I've looked at the locking hub, but I thinks that's more for real heavy 4wheeling.
    Or should I just carry a come Along?
  2. Dec 6, 2015 at 7:17 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Learn about tire pressure as it relates to getting unstuck
  3. Dec 6, 2015 at 7:25 AM
    Pigpen
    Dan
    Northwest Montana
    I've used a come along to get out of some mild situations. They work, but not well. A hi lift jack is better, but still a whole lot of work. Obviously a winch is the best option, but not everyone is ready for that kind of commitment.
    I carry all 3 in my truck :D
    Tires should be first and learn what you can do with your truck - your skills will improve. Tru trac will be a huge help and worth the money. If you fall in love with wheeling, you're gonna end up with lockers though. Just drive it and mod as you find things you want to change.
    Most importantly, remember that getting stuck is fun and it's how we become better drivers (and better at recoveries).
  4. Dec 6, 2015 at 8:02 AM
    Marc70
    Marc70
    Northern Ontario
    Thanks all. Don't have any kind of lsd diff, but went out and was impressed how well I could drive what I thought was 4wd roads, in 2wd.
    The tires are awesome. I have a short box 4door truck.
  5. Dec 6, 2015 at 12:17 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You will need an air pump, but you should have that already. I can vouch for airing down in the sand. Have got stuck twice before airing down, then got myself out after airing down. I have Trailhead deflators and set them at 12psi.
  6. Dec 6, 2015 at 1:45 PM
    HBMurphy
    Paul
    So California Coast
    None
    The cheapest traction device you will ever have:
    MV50
    Many swear by them. Less than $75. Nice threaded connection so you don't have to hold it. Battery clamps (don't bother getting one with a cigarette lighter adapter - too much amperage for a good compressor). Keep your engine running while you are using this.
    BTW - I've never owned this model but it is a very good, inexpensive one.
  7. Dec 6, 2015 at 1:48 PM
    Chuy
    Lakeside, CA
    Silver Taco
    That's what I have - Q Industries. It gets quite hot after 5 minutes but it keeps ticking ... My bro got it for me from Costco many moons ago. About $50 back then.
  8. Dec 6, 2015 at 1:59 PM
    HBMurphy
    Paul
    So California Coast
    None
    As it should...
