Limited vs Sport vs Off Road vs TRD Pro stock suspension/ride height
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alegerlotz, Jul 7, 2020.
  1. Jul 7, 2020 at 11:30 AM
    alegerlotz
    alegerlotz [OP] Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    I drive a 2017 Limited 4x4 AT that is completely stock.
    I've been having a hard time trying to determine if the factory ride height is the same between all of these trucks (it appears that the Pro starts 1.5" higher) and for any that are higher from the factory, what components are responsible for that difference? Springs? Springs + Shocks? Are control arms, sway bars, sway bar links all the same?
    I'm considering moving to bigger tires and I see a lot of information about stock Sport/OR/Pro upgrades, etc... but Limited models seem few and far between on this forum.
    I'm trying to determine if the same lift (lets say 1 inch) on a Sport or Off Road will lift a Limited the same amount, or if the suspension is different on the Limited since it seems to be more of a "luxury" model.
    Ultimately I'm thinking of moving from 265/60-18 tires to 265/65-18 tires (30.5" to 31.6") on the stock rims (18x7.5 18mm ET30) and adding bilstein 5100s with stock springs on the first notch (one notch above stock springs) to deal with any rub that may occur. Rear would remain stock height, but with the 5100s as well.
    Thanks for any info you can provide.
  2. Jul 7, 2020 at 11:37 AM
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    They are all the same ride height expect for the Pro which has a 1 inch lift in the front (rear lift is the same as other models). And it's springs that provide lift, not shocks.
    Chew and alegerlotz[OP] like this.
  3. Jul 16, 2020 at 12:51 PM
    Cdnguy
    Cdnguy Member
    Bilstein shocks WILL lift a vehicle depending on what notch you put them on. Alegerlotz, I'm looking to do the exact with my Sport. Just enough to get a larger tire in there. I have 17 inch rims though.
  4. Jul 16, 2020 at 12:58 PM
    alegerlotz
    Los Angeles
    I'm considering either the Bilstein 5100 setup or the Eibach Pro Coilovers paired with Eibach rear shocks. With the Coilovers I can go anywhere from 0" to 2" of lift, correct for any lean, etc... I'm not in a hurry because my stock tires aren't used up yet.
