Limited vs. TRD-Offroad
Discussion in 'General Tacoma Talk' started by mrcool, Sep 10, 2024.
  1. Sep 10, 2024 at 6:03 AM
    mrcool
    mrcool [OP] Member
    Hi!
    Im currently looking for a new Tacoma and I found this awesome Limited. It has a 3in lift, 33in tires, and aftermarket TRD parts.
    I'm looking for a Tacoma that is a great daily but also capable of handling challenging trails. I do not know much about cars at all, but I know alot about Overlanding (Driven jeeps, 4wheelers, etc). I just want to know how the Limited compares to an Offroad when it comes to overlanding.
  2. Sep 10, 2024 at 3:17 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Crawl under it and check for rust holes and delaminating of frame.
    EubeenHadd likes this.
  3. Sep 10, 2024 at 3:26 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    The limited will be missing a locker unless the previous owner specifically installed one. The TRD Off-road will have a locker from factory. My experience going down trails with and without a locker make it a personal requirement to have a locker in the back at least, and also in the front of possible
  4. Sep 10, 2024 at 3:46 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    I've done fairly moderate offroading in my TRD Off Road and have found the locker useful - also the 'off road cruise control' is great for long & tricky descents. Not sure if the limited offers either of those things.
  5. Sep 10, 2024 at 8:30 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Lifts and bigger tires and suspension changes are changes I would rather decide. Just my humble opinion. I would rather have the basic mechanical components (locker, crawl-mode for rough spots) than inheriting some previous opinion of a good suspension change.
    If you really are taking up overlanding, off-road capability is necessary and you will want money for bed racks, RTTs, skid plates, better shocks and leaf springs (that comes with a minor lift but more for the better pure strength), ditch lights, winches, ...
    The most expensive option you encounter may well be this forum ... :spending::mudding:
    soundman98 likes this.
  6. Sep 11, 2024 at 5:57 AM
    mrcool
    mrcool [OP] Member
    Really? huh. My friend has a Jeep that we have taken on technical trails without a locker. I don't see myself really driving in snow or mud, but i will have a bumper and wench
  7. Sep 11, 2024 at 8:05 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    The difference wheeling with and without a locker is massive tbh. It makes every low traction situation less problematic. Every water hole gets more traversable, every rock garden takes less momentum, every washout crossover gets much easier to cross. You can achieve most of the same with axle/chassis flex, my friends run a wrangler without lockers without issue down the same trails I do, but they need flex and momentum where I don't, and if they get lockers front and rear I'll literally never keep up in the technical stuff.
    mrcool[QUOTED][OP] likes this.
  8. Sep 11, 2024 at 6:33 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    limited is going to be more road/comfort focused, where offroad is focused on, well offroad. i believe there's slightly different gearing, the shocks are valved differently, the offroad gets a rear locker, offroad traction control modes, and raw plastic fender trims, where the limited gets the hood scoop, painted fender trims, and extra switch blanks in the interior for the traction control modes.
    if you're actually going to use it offroad, the offroad version has overall better options to start from. but the majority of the truck is the same for the limited, so it's not like the limited can't do anything offroad, it just can't go as far offroad.
