Limiting straps on basic lift set-up: Let's Discuss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EatSleepTacos, Sep 20, 2016.
  1. Sep 20, 2016 at 2:27 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
  2. Sep 20, 2016 at 2:29 PM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    Also curious about this. I have OME886s on my truck and I occasionally hear them topping out(i'm currently without a front bumper), and I'd like to not let that happen.
    EatSleepTacos[OP] likes this.
  3. Sep 20, 2016 at 2:34 PM
    MeFryRice
    MeFryRice Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    I'm interested in this as well but cautious as to how I would mount them, know what length strap to purchase, etc.
  4. Sep 20, 2016 at 2:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I bet if you jacked up your truck so your front tires were at full droop and took a measurement, the guys from the company would be able to help you out.
  5. Sep 20, 2016 at 2:37 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Highly recommend limiting straps of you're running or plan on running extended travel coilovers with aftermarket upper control arms. These are how mine are mounted. If the coil doesn't sit just right, there's a good chance the UCA will contact the coil.
  6. Sep 20, 2016 at 2:40 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What I'm curious of is everyone's opinions on using it with a basic bitch set-up, like OME or Bilstein standard travel suspension.
  7. Sep 20, 2016 at 2:43 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    IMHO, it would only be worthy insurance if you're running aftermarket UCAs. However, someone is going to come here and call me an idiot, they're probably right.
  8. Sep 20, 2016 at 2:43 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    same here. subbed for info in case somebody's running them on a similar set up to mine, 887's LR UCA's
  9. Sep 20, 2016 at 2:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Makes sense, since I believe you get more droop from UCAs.
  10. Sep 20, 2016 at 2:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Limiting straps are much more common on a live solid axle setups, with coil sprung vehicles, like Wranglers. On solid axle vehicles they can prevent you from over-droop your axle and have a spring literally fall out of the spring seat. Not a problem on the Tacoma IFS. Of course IFS has different challenges, like more fragile CVs that do not like operating at extreme angles.
    Toyota engineers have said the limiting factor in the droop of the Pro suspension is the ball joint of the stock UCAs. I would imagine that even if you went to Light Racing UCAs that maintain the factory style ball joint they would be limiting. I think you could maybe make a case for if you go to a uniball UCA like Total Chaos that allows for an extra inch of droop in the suspension, which would allow things to be flexed further than the factory design. However, the straps say that you loose about an inch of droop by using them. So then what is the point of paying more to run a UCA that allows 1" extra droop, to pay more to run limiting straps to eliminate the gain? Of course this assumes the shocks have the extra inch of droop to spare.
  11. Sep 20, 2016 at 3:06 PM
    tacot0wn
    CO
    What about for people(like me) that top out their shocks as their droop limit? That's not a good limiter.. correct me if im wrong.
  12. Sep 20, 2016 at 3:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would think that in your instance they'd be good! In the article it mentions the 5100s on the T4R are topping out, hence the need for straps.
    tacot0wn[QUOTED] likes this.
  13. Sep 20, 2016 at 3:19 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    It's really simple. SALES GIMMICK. Get your shock specs. and jack the truck up and measure at full droop. If the shock is maxed out, might think about getting limit straps before you blow the seals. If you lifted it, go ahead and get superbumps so you don't bottom out regardless, they are fairly cheap and take about 5 minutes to install, plus might save your flairs from popping off. even with extended travel and uniball uppers, the LCA will most likely limit travel and you'll be fine, unless you have standard shocks, which would be dumb to get more travel if you can't use it. The rear will be limited by the leafs unless you did a shackle flip or have some major lift blocks, which would be totally stupid anyway.
    So, no, you shouldn't need limit straps unless you went out and got uniball uppers, went like 2-3" lift on standard shocks, which in that case, you deserve to blow out the shocks for doing something so stupid anyway. Limit straps are more common with long travel guys. I run 3" lift, extended travel shocks, uniball uppers, and still have 1/2-3/4" shock travel left and the LCA is maxed out and won't go any farther. If your control arms hit coilovers, I'd be concerned something isn't installed correctly? My rear has leaf pack, 1" block, extended shock, and the leafs limit shock travel before full extension. I run super bumps because when i stuff the wheel, I kept popping off flairs, even after a lot of trimming. IFS angle is just fine, but wouldn't want anymore. Really, how often will it be at full droop when moving anyway? If I had more usable travel, like a total chaos long travel kit with long travel shocks, I'd get upgraded axles to handle the extra binding at full droop. If someone sells you a long travel without them, shop somewhere else!
  14. Sep 20, 2016 at 3:38 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    IMO not necessary, unless extended travel suspension with poly bushings.
    Taco47 likes this.
  15. Sep 11, 2018 at 6:44 PM
    Carl_z33
    Carl_z33 Well-Known Member
    Carl
    2014 Toyota Tacoma TRD OR 4x4 DCSB
    Where did you get the limit straps from
  16. Sep 11, 2018 at 6:49 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    toku58 likes this.
  17. Sep 11, 2018 at 7:01 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Check out my avatar. I installed them on my truck. After my (spacer) lift, my UCA was hitting the coil on one side when I would catch a little air. I just drilled a hole in my strut tower on the frame and used some grade 8, 1/2" bolts to attach the top. The bottom is attached to the lower strut bolt. I've checked and mine limit my downward droop about a half an inch.
    I measured several times before drilling and ended up having to drill two different holes to get them where I wanted them.
    It solved my problem of the UCA's hitting the coils.
  18. Sep 11, 2018 at 7:04 PM
    bullaculla
    Da big big island!
    That's why you get the adjustable clevis. They also do stretch a little over time.
  19. Sep 12, 2018 at 8:56 AM
    Carl_z33
    Carl
    Looks like you used the same bolt from the LCA that holds the strut correct?
  20. Sep 12, 2018 at 7:50 PM
    winkel
    Corydon, IN
    Yes, that is correct.
