Limp mode
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pauling21, Sep 19, 2017.
  1. Sep 19, 2017 at 9:39 AM
    Pauling21
    Pauling21 [OP] New Member
    Will
    95 tacoma
    None
    my 95 tacoma kicks in and out of limp mode randomly. When this occurs the check engine light kicks on and off. My self and the dealer have put a scanner on it when this happens and it won't connect. So I tried a used computer and it's the same thing.
  2. Sep 19, 2017 at 10:08 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Does it ever set a code? If so what code?
  3. Sep 19, 2017 at 10:12 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I thought Limp mode was only on the 03-04 and previous years were cable driven?
    OP more details about your truck would be helpful too (engine type, cruise, trans, etc)
    mechanicjon likes this.
  4. Sep 19, 2017 at 10:28 AM
    Pauling21
    Will
    95 tacoma
    None
    It is a 2.7 L 5 speed. It will give me exhaust codes but that's because I cut the cat out thinking it was clogged up. Whenever it starts to act up scanners won't connect to it.
  5. Sep 19, 2017 at 1:08 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you mean the MIL light flashes on and off??
    Something is wrong is your OBII plug corroded ??
    Rodents chewing on wires ??
    Without the Cat the light should always be on unless you keep clearing the code .
    You changed ECM`s your sure it was good??
    Ecm get wet ??
    Bad connection some place .
    As far as I know 95.5 did not have a limp mode
  6. Sep 19, 2017 at 4:13 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    There are fail-safe modes, like if the coolant temp sensor isn't working the computer assumes the coolant is at 180°F. Same for other sensors like the MAP.
    But how do you know it's in limp mode if the scanner won't connect? I mean what's the difference between limp mode and just running really bad?
    Perhaps an electrical problem like low voltage? This would cause the engine to run bad and the computer to not communicate.
    Dalandser likes this.
  7. Sep 19, 2017 at 5:30 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    The factory repair manual has a fail-safe chart for 1996. It's limited to P0100 (MAF), P0110(IAT), P0115(ECT), P0120(TPS), P0135(O2), P0141(O2), P0325(Knock Sensor), P0336(CPS) and P1300(Igniter Circuit Malfunction).
  8. Sep 20, 2017 at 11:18 AM
    Glamisman
    Glamisman Well-Known Member
    When the CEL/MIL flashes like that it is the PCM telling the driver STOP you are damaging the motor or the catalytic convertor. Since you have the cat cut out the the PCM is going into limp home mode. You might have to investigate the O2 sensor bypass hack that I have read about.
  9. Sep 20, 2017 at 4:19 PM
    Fstrnyou
    Fstrnyou Well-Known Member
    Craig
    2002 XC 2.4 5spd 2wd
    Many many miles.
    I was under the impression that limp mode just added a bunch of fuel and pulled a bunch of timing. And limited throttle on vehicles that are TBW.
  10. Sep 20, 2017 at 4:26 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Isn't 'limp mode' also referred to as 'open loop' ?
  11. Sep 20, 2017 at 4:29 PM
    Fstrnyou
    Craig
    Many many miles.
    No. There are special fuel maps and timing maps used if the ECU determines the conditions are "abnormal".
    On my Speed6, there are "abnormal" fuel, timing, throttle control, and load maps. In addition to the standard OL/CL maps.
    All the tuning I do on that car, I'd like to be able to tune this Taco. Strongly considering the Bluetooth OBDii adapter thingy so I can at least monitor some things. I already have TorquePro.
  12. Sep 21, 2017 at 7:39 AM
    Glamisman
    open and closed loop refer to if the PCM's base injection/timing maps are modified by the O2 sensors or not.
  13. Sep 21, 2017 at 7:44 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I log a lot of data on my turbo truck. When I threw po325 for knock sensor the truck goes to "limp mode", the stock ECU pulls timing and adds fuel. That is open loop, the ECU is ignoring all the sensors and feeding it a pre calculated tune.
  14. Jun 14, 2024 at 6:01 PM
    xxwarxxmachine
    xxwarxxmachine Active Member
    Jeremy
    97 Toyota Tacoma 2.4 2RZ-FE
    What ended up being the solution to this?
