Line Out Converter Help needed- which harness wires to tap?
Discussion in 'Audio & Video' started by Slider57, Mar 6, 2014.
  1. Oct 6, 2015 at 9:39 AM
    #61
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    Nice. I just applied DynaMat/Dynapad in the trunk area and am working my way around the car. I'm going to get the doors done today and then wait until the rest of my material gets in to do the roof and the floor. I will do the floor last and install the system at the same time.
    Revelations likes this.
  2. Oct 6, 2015 at 9:40 AM
    #62
    EasyLivin
    Jeff
    Euless, TX
    Good heads up on the gain settings. I am looking forward to getting the chance to mess with it!
  3. Nov 1, 2015 at 5:52 PM
    #63
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    OK fellas,
    If I use lci7, I can add a pair of subs and a amp & keep all factory controls, ie: steering wheel, usb port etc..
    Is the above correct?
    I want to keep factory head unit... I will update factory speakers at a later date.
    Thank you...
  4. Nov 2, 2015 at 4:33 AM
    #64
    EasyLivin
    Jeff
    Euless, TX
    Yes. With no harness you will have to tap the factory harness for the speaker wires. You can use Metra cables with a small bit of modification to bypass cutting the factory harness and still use the factory head unit.
    voz likes this.
  5. Nov 2, 2015 at 4:55 AM
    #65
    voz
    VOZ
    VOZLAND
    The Clean One
    I need to look it up.. You have a part number or thread?
  6. Nov 2, 2015 at 7:00 AM
    #66
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Read through this thread. First page had information on metra cable numbers.
  7. Nov 3, 2015 at 8:43 AM
    #67
    voz
    VOZ
    VOZLAND
    The Clean One
    AHHH, my dumb ass missed it...
    thank you!
  8. Feb 25, 2016 at 10:16 AM
    #68
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    what would i use for a 2016 non JBL HU to add a line converter, is there a harness for that?
  9. Feb 26, 2016 at 8:07 PM
    #69
    Revelations
    2014 MGM DCSB
    There is no plug an play harness to add in a LOC. You either need to cut your factory wires, or do what some of us did and buy a set of stereo harnesses and wire that in between the radio and the truck's wires. The harness part numbers are in the first page of this thread. I assume you're adding a LOC to run aftermarket amps and speakers right?
  10. Feb 27, 2016 at 7:43 AM
    #70
    Burbanza
    Burbanza Member
    After watching the ********* video, will a LOC do the trick with a stock HU or will I need their ReCurve unit to adjust the detuned signals from the HU? Part of me thinks they are pushing their recurve and that the detuning isn't a huge deal for a non audiophile. Thoughts?
  11. Feb 27, 2016 at 8:25 AM
    #71
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    depending on your stock deck, there is no detuning from the factory. the JBL system might do it. i have Entune Plus and get full range out
    likely a marketing tactic
  12. Mar 14, 2016 at 8:19 AM
    #72
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    The wiring diagram / chart on page 1 of this thread is incorrect as it applies to a 2014 Entune non-JBL radio.
    It's say's "do not use" the "O" wire position. This wire is required for radio button illumination.
    It also says "do not use" the "J" wire position. This wire is required for headlight activation dimming of the radio.
    If the thread is going to be a sticky with a diagram and specs, it should be correct. Just saying'.......
    Would have saved to time of pulling the radio to troubleshoot twice.
    TW member Revelations posted a great thread confirming my findings and helping to solve the missing wire required to illuminate the radio buttons issue.
    https://www.tacomaworld.com/threads...lights-on-oem-radio-after-loc-install.394575/
  13. Mar 14, 2016 at 11:08 AM
    #73
    proven21
    where do the harnesses plug into? They connect to each other but how do they connect to the head unit?
  14. Mar 14, 2016 at 11:12 AM
    #74
    proven21
    ok so i cut into the wires that come out of the back of the HU and then wire in the wiring harnesses from Metra I have and then wire the harness to the LOC? Im so confused. I have no clue what I am doing.
  15. Mar 14, 2016 at 12:21 PM
    #75
    UBYBC
    2014 Tacoma TRD OR
    one male harness plugs into the deck, one female harness plugs into the truck OEM wiring. Connect your equipment in-between these two harnesses. Doing this correctly should mean you do not have to cut or splice any factory wires.
  16. Mar 14, 2016 at 12:23 PM
    #76
    proven21
    none of the harness plug into the back of the 2016 entune headunit and fit. So when you say one male plugs into the deck and one female plugs into the OEM truck wiring I dont know what that means?
  17. Mar 14, 2016 at 12:26 PM
    #77
    UBYBC
    2014 Tacoma TRD OR
    Sorry, I have not seen a 2016 radio yet. I know that 2014/2015 use a male harness into the deck. I just installed one myself.
    Sounds to me like you have the wrong harness? Can you post part numbers or pictures of both harnesses? and the back of the radio too.
  18. Mar 14, 2016 at 3:40 PM
    #78
    Revelations
    2014 MGM DCSB
    Post a pic. It will help us understand what you're looking at.
  19. Mar 20, 2016 at 3:49 PM
    #79
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    I just upgraded my 2016 entune premium (non/JBL) with the harnesses referenced earlier and they do connect to the HU and factory connectors.
    UBYBC and Revelations like this.
  20. Mar 21, 2016 at 12:48 PM
    #80
    UBYBC
    2014 Tacoma TRD OR
    I thought he was wrong and tried to help him, until he told me to piss off...
