line outs, RCA's?
Discussion in 'Audio & Video' started by pwrstrk02, Apr 13, 2010.
  1. Apr 13, 2010 at 9:08 AM
    pwrstrk02
    pwrstrk02 [OP] Well-Known Member
    randy
    kansas city missouri
    2010 4x4,dc,off road, black pearl
    im building my system upgrade on paper for now. i dont like how the double dins and the single w/compartment look, so i want to stick with my factory head unit. instead of me taking my dash apart just to see, could any of you that has taken theirs out tell me if the factory stereo has line outs/RCA's? i will be running it all through a JL audio CL441DSP "processer", 2x JL Audio 10w1's, 1 Rockford P300-1 for the subs, and 1 Rockford P400-4 for the mids and highs (which i havn't decided on yet).
  2. Apr 13, 2010 at 9:19 AM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    No, the factory radio doesn't have line out's but if you use the processor you will just use high level(speaker wire)inputs to the processor and you will have RCA outputs from there. If you don't use the processor you can use hi-lo adapter to do the same thing but the signal will not be as good.
  3. Apr 13, 2010 at 9:38 AM
    pwrstrk02
    randy
    the JL Audio clean sweep is the one im eyeballing. thanks for the info DAUDIO. i think that saved me about and hour. I will buy you a pop sometime.
  4. Apr 13, 2010 at 3:26 PM
    Daudio
    North Jersey
    '02 SR5
    make it a beer and you got a deal :cheers:
  5. Apr 28, 2010 at 7:11 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I know it won't sound nearly as well, but how bad is the stock deck EQ curve just outputing it to the high level inputs on a 4 channel amp? I guess I could try as I don't plan on getting the processor right away (but JL CleanSweep is in the plans). Is it only at high volumes it cuts down the bass ect?
  6. May 10, 2010 at 9:59 AM
    jassco
    NH
    2023 TRD Offroad
    FYI I just ran a Navone LOC off my stock HU using both a scosche reverse and standard adaptor to a 100X4 amp. After deadening the doors and console I don't need to turn up the volume so high only 15-35 range. I don't really need the cleansweep anymore because it sounds great and I still get great base at those volumes with 6x9's up front. I did put 6 1/2 in rear though (cut panels) and fills out much better then crappy celing speakers - which I just terminated behind the dash.
