Line-X or Powder Coat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carcharias, Jan 22, 2011.
  1. Jan 22, 2011 at 9:39 AM
    carcharias
    carcharias [OP] Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    New to the boards here w/ my first Tacoma (2011 AC 4x4) after living w/ a Wrangler for 11 years. Seems a Taco can be tricked out more than that Jeep!
    Anyway, I'm virtually positive that I'm getting an Avid light bar and sliders sometime in the next month, but since I know nothing abt painting parts I thought ya'll might have some advice.
    Should I simply powder-coat these or do something like Line-X? Will one last longer, or does one look better in your opinion? I'm waiting for quotes, but does one cost more? Thank you!
  2. Jan 22, 2011 at 9:54 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    it all depends on you.
    will you be off roading hard? if so, no line X. it will just chips off the first time you hit a rock with any force. same with powdercoating.
    if you were to just spray can it, then the touch ups are very simple, and quick.
  3. Jan 22, 2011 at 11:07 AM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    So, straight-up spray paint, huh? What prep is needed?
    My off-roading isn't rock-climbing, but mud/snow/desert.
    Thanks for the response, btw, and sweet truck! I dig the wheels...
  4. Jan 22, 2011 at 4:03 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    To prep them for spray paint, just clean them off well first with a solvent that removes oil, etc... Even parts cleaner should be OK.
    If they come primed, jump right to the next step. If they are bare metal, you should sand them with 400 grit paper, then prime them. Apply 2-3 thin coats, as thick coats can run, and take long to dry. Once primed and dried, go to the next step.
    Sand the sliders, lightbar, whatever it is with some 600 grit paper. Sand completely, so no "shiny" remains.
    Once sanded, paint them up! Use thin coats of paint, as it will dry faster, and eliminate the occurrence of runs. Also, paint in a relatively clean environment, to keep dirt, and debris out of your work.
    For added protection, you can spray some clear on them as well. The clear coat adds quite a bit of protection, as it's laquer-based, and quite thick. It's going to make touch-ups tough, as you'll have to re-paint the entire part, so keep that in mind.
    Hope that helps!
  5. Jan 22, 2011 at 7:23 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Awesome!! Yeah, that definitely helps, thank you!
  6. Jan 22, 2011 at 10:00 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    x2 on the DIY paint job. It's not going to be a good feeling ($$) to take the part BACK to the powdercoaters/LineXers when you get a scratch. Rustoleum flat black FTW!
  7. Jan 23, 2011 at 2:33 AM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    if you look t some of my pictures, you can see that i actually painted my wheels myself (GF helped) but it was worth the time it took.
    make sure you prep well though. degreaser, and sanding.
  8. Jan 23, 2011 at 4:01 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I'd go with line-x. I had my Avid lightbar line-x'd and I'm loving it. I have hit some horrible stuff with it at my hunting camp and haven't had anything chip off. I love the way it looks also!
  9. Jan 24, 2011 at 7:50 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Just got a $575 quote to Line-X all three parts. Seems a bit steep even for all the goodness it'll bring...
  10. Jan 24, 2011 at 7:54 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    i got the Avid light bar and sliders.
    i powder coated it and it only cost me 80 for all three to be done. so i figured i'd give it a shot, never done either so i can let you know how they turn out
    TacoMods likes this.
  11. Jan 26, 2011 at 7:54 AM
    bayoubengal
    bayoubengal Well-Known Member
    I'd go with the line x as well. I got
    My light bar on my taco linexed and have hit stiff with
    If before and ive had no chipping either.
    Line x is quite expensive but idk how the linexers do it
    Where you live but the line x of baton rouge where I live
    Has lifetime warranty so any chipping on anything they'll respray it for free.
    Another thing is that the textured look of the line x looks badass
  12. Jan 26, 2011 at 8:06 AM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    Line-x fades over time regaurdless of what anyone tells you, I would powder coat, Line looks like ass after 6 months. I have had it done on 2 trucks, wouldn't do it again unless it was covered by a shell on the bed. And yes it does chip easier then what the line-x peopes say
  13. Jan 10, 2014 at 8:53 AM
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    '22 TRD Pro Taco; 6MT
    Sub'd. Got mine in the mail last week. Bare metal and ready from prime and paint.
  14. Jan 10, 2014 at 10:37 AM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    I used line-x. Let me know if you want pictures.
    I had my sliders coated for $170. My sub box for $30 and my tailgate reinforcement coated for $70. Shop around that line-x price is steep.
