Line-X Whole Truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chayes119, Feb 18, 2014.
  1. May 9, 2014 at 2:31 PM
    #201
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    And loss of quute a bit of aerodynamics since the body is no longer smooth.
  2. May 9, 2014 at 2:38 PM
    #202
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    truck looks awesome!!!!!!! I wonder how hard it will be to get all the dirt off though.....
  3. May 9, 2014 at 2:49 PM
    #203
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Golf balls are not smooth and have excellent aerodynamics.
  4. May 9, 2014 at 2:54 PM
    #204
    bueller
    bueller Well-Known Member
    AZ
    The smooth body has nothing to do with aerodynamics. The shape is what matters. A rough or uneven surface ^^like a golfball^^ actually helps in aerodynamics. I've built a few sand drag quads and it's been proven that on the intake, a rougher surface flows faster and better with less turbulence that a smooth surface.
    So we're back to the negligible 80 lbs.
  5. May 9, 2014 at 2:58 PM
    #205
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    OP, How bad do you guess this will fade over time?
  6. May 9, 2014 at 3:33 PM
    #206
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    I had a problem with dirt getting in my Line-X'd bed on my previous truck so I took the power washer and found a reasonable setting that got it back to Black a couple times each month. Probably can apply the same thought to his Line-X.
    I still don't know if I'd do my own truck, mainly because I like my magnetic gray metallic so much, and I've got an OME lift+rims+tires to save up for before I think about something like this. However, most of the concern/nay-saying in this thread seems to be conjecture.
  7. May 9, 2014 at 3:49 PM
    #207
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Rhino-shine. It works great, I have used it on bedliners on my other trucks. I didn't read all 11 pages so my apologies if this has already been mentioned. It can be found at Rhino liner install shops, about $15 for a bottle.
  8. May 10, 2014 at 12:15 AM
    #208
    gospurs21
    gospurs21 Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    looks tooo sick! wheres your bumper?
  9. May 10, 2014 at 12:58 AM
    #209
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Looks great! I've seen a few ghetto rattle can bedlinered trucks around here, but looks nothing like yours. Very nice :cool:
  10. May 10, 2014 at 4:36 PM
    #210
    Chayes119
    Chayes119 [OP] Long Member
    Georgia
    06 PreRunner SR5 BLK
    I have a relentless fab front plate bumper on order should be here next month.
  11. May 10, 2014 at 4:38 PM
    #211
    Chayes119
    Georgia
    The product that was sprayed is called Line-x premier the. It is top coated with a uv resistant paint. It will not fade for life. If it does they will respray.
  12. May 10, 2014 at 4:39 PM
    #212
    Chayes119
    Georgia
    The UV top coat that is applied makes it more like paint. It washes off easily.
  13. May 10, 2014 at 4:40 PM
    #213
    Chayes119
    Georgia
    I have not lost any MPG. I still get the same 16-17 I have always gotten since my lift.
  14. May 10, 2014 at 4:41 PM
    #214
    Chayes119
    Georgia
    I was just about to say that about golf balls.
  15. May 10, 2014 at 4:42 PM
    #215
    Chayes119
    Georgia
    I agree. Also line-x can color match to any color. All you need is the paint code.
  16. May 10, 2014 at 4:51 PM
    #216
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I see what you did there. :D[​IMG]
  17. Sep 16, 2014 at 7:01 AM
    #217
    Chayes119
    Georgia
    I installed my front bumper this weekend. The truck is complete.... lol it is never complete! What should I do next....
  18. Sep 16, 2014 at 8:12 AM
    #218
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    :eek: :bowdown:
  19. Sep 16, 2014 at 9:50 AM
    #219
    tomwilson74
    Tom
    West Virginia
    That is one AWESOME truck dude!!
  20. Sep 17, 2014 at 7:32 PM
    #220
    Chayes119
    Georgia
    Thanks I think it came out badass!
