Linear clutch pedal return spring pictures?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tomtom, Nov 2, 2014.
  1. Dec 29, 2019 at 2:27 PM
    tlwaggie
    tlwaggie New Member
    2004 silver Tacoma trd
    Does this also solve the "squeaking" noise on a 2004 Tacoma, when pressing down on the clutch pedal? Is there a TSB(technical service bulletin) for a 2004 Tacoma on the clutch pedal assembly? I found the TSB for 2005 and above, but not for 2004.
  2. Dec 29, 2019 at 3:14 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    The squeak is caused by friction between the torsion spring and the retention tab on the clutch pedal assembly. Normally there is a plastic U-shaped bushing between the two parts, but it tends to break and need replacement often. I'm not aware of any TSB for this issue, but replacing the torsion spring with a linear spring is a tried and true fix, and one I've done myself. I wish I'd had the guts to try it before shelling out $500 for a new clutch pedal assembly (which then started to squeak again after 1 year).
    GQ7227 and Gyrkin like this.
  3. Sep 10, 2020 at 9:11 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Is this a Toyota part number?
    EDIT: Yes, dummy, keep reading. It is.
    Wyoming09 likes this.
  4. Sep 10, 2020 at 9:23 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did you ever try putting some fine lubricant on everywhere before going through that hassle or was the plastic U-shaped bushing shot to pieces by then
  5. Oct 21, 2020 at 5:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is the plastic U-Shaped bushing, retention tab able to be seen on this pic?
  6. Oct 21, 2020 at 2:29 PM
    Kiloyard
    Phoenix, AZ
    No, it's too dark to see exactly what is going on here, but I think you've confused the brake pedal with the clutch pedal.
    GQ7227[QUOTED] likes this.
  7. Oct 21, 2020 at 3:15 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :annoyed::facepalm: you are likely correct, I could not see up there and was trying to focus the tablet camera anywhere that would show up
    I shall try it again
  8. Oct 21, 2020 at 3:55 PM
    Kiloyard
    Phoenix, AZ
    Here you go, I took a picture of mine (obviously my torsion spring is no longer there). You can't just replace the bushing while the assembly is still in the truck though, and even then, it's only a matter of time before it breaks again. If yours is damaged I recommend you do the modification - it's easier than replacing the bushing and is a permanent fix.
    GQ7227 likes this.
  9. Oct 21, 2020 at 4:23 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I sprayed nutz lube which is a corrosion inhibitor!!
    Very good mileage onit with no squeak
    Just a popping sound that might be this plastic bushing
    Idk!
  10. Oct 21, 2020 at 4:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I read somewhere that it takes a toll on the knee, that mod does?!?
  11. Oct 21, 2020 at 4:32 PM
    Kiloyard
    Phoenix, AZ
    Not if you use the right spring. Get the clutch pedal return spring from Toyota and you'll be fine. I've been running it for, I don't know, at least a year now and I'm cursing myself for not doing it 10 years earlier.
  12. Jan 3, 2024 at 3:04 PM
    Nacho96
    Nacho96 Member
    TJ
    1996 Tacoma 3.4 V6 4x4
    Got sick of pulling up on the return spring to get the cruise control to work. Did this fix today using the 4 cyl return spring. Took 10 minutes using a screwdriver and no more squeak. Highly suggest. This was the old spring, part no. above is the new return spring.
  13. Jan 3, 2024 at 3:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @turbodb
    This is what I was trying to describe to you
    Madjik_Man[QUOTED] likes this.
  14. Jan 3, 2025 at 8:13 AM
    c0climber
    c0climber Well-Known Member
    Northern Colorado
    2001 Tacoma
    Alright so dumb question and I know its an older post, my 01 clutch pedal is squeaking bad so tried ordering 90507-14030 but it appears to be out of stock and no longer made. Made a trip to a couple scrap yards and couldn't find any. Didn't see a consensus on whether using the brake springs worked or not.
    So would would using the brake springs work, or is there a #70 spring size that works?
  15. Jan 3, 2025 at 12:31 PM
    #35
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Google the part number and you'll get 20 dealers that have it in stock for $5-7.
    Speedytech7 likes this.
  16. Jan 3, 2025 at 1:00 PM
    #36
    Speedytech7
    Yeah I bought two within the last 6 months, don't think it is a dead one yet
  17. Jan 3, 2025 at 2:10 PM
    #37
    c0climber
    Northern Colorado
    2001 Tacoma
    I'll hold off on the sarcastic response since I already stated I tried ordering but hey I'll go through whom I've ordered through already:
    Olathe Toyota
    Lakeland Toyota
    Camelback Toyota
    Carlock Toyota
    Richmond Toyota
    Hudson Toyota
    Corwin Toyota
    Erlich Toyota
    Larry H Miller Toyota
    eBay
    Rummaged through 2 different scrap yards in NoCo.
    I've ordered with several different Toyota dealers and 2 different OEM part dealers and all have told me it is discontinued and cancelled orders or called to say they couldn't place it. So yeah, I wouldn't have asked if I hadn't already tried Googling the part number or researching it first. It isn't sold on Amazon, Rock Auto, or any of the other dealers I normally order from, I've tried calling a dozen different stores all online and all have told me the same as the others I placed orders with that said they had it in stock.
    Would you be so kind as to inform me as to where you ordered from?
    Oh hey here is the standard email from 4 of the Toyota dealerships:
    We regret to inform you that your order is being cancelled due your part(s) being on national back order by Toyota. These types of orders do not hold an ETA for fulfilment. Typically these back orders could last 6 months plus to arrive and ship. We sincerely apologize for any inconvenience.
    Your order was cancelled and the payment voided. Since we did not manually collect the payment, it was never debited from the account. Therefore the preauthorized charge will fall off the account shortly after the cancellation. Please contact us for any questions or concerns you may have.
    All dealerships cancelled the orders or called within days to inform. Richmond Toyota thought they could source it but after 2 weeks called and emailed to inform me they couldn't actually find any of the parts nationally, so I pretty much gave up but still look around and call from time to time as I have been searching since at least September when @turbodb posted his walk-through on it.
    #37
  18. Jan 3, 2025 at 3:09 PM
    #38
    time623
    James
    AZ
    Damn, never seen that before. I've wanted to order a lot of out of production parts before, but they've never shown up as in stock at literally every single Toyota parts department in the nation like the clutch spring does.
    People have also successfully used the brake pedal return spring; 90905-07028, its showing up in stock as well. If that means anything.
    Or the original swap, a #70 spring from the hardware store. If its labeled #70 it should work.
    More info on that:
    https://www.yotatech.com/forums/f2/fixed-stupid-plastic-clutch-pedal-bushing-19137/
    #38
  19. Jan 4, 2025 at 4:58 AM
    #39
    bjd129
    bjd129 Member
    Denver, CO
    2003 Tacoma TRD
    I just ordered and picked one up 2 weeks ago from Stevinson Toyota West in Lakewood give them a try. Ordered it online from the toyota parts site here is the part number i used 90507-14030
    #39
  20. Jan 4, 2025 at 5:31 AM
    #40
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I used a brake pedal spring and it works fine.
