Lines on Front window?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheWildMan, May 11, 2024.
  1. May 11, 2024 at 6:24 PM
    TheWildMan
    TheWildMan [OP] Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Started noticing vertical lines on my driver side window. They're not always as visible, but I really noticed the lines today. Tied taking pictures but it didnt really show up. This is a photo from a reddit post, same thing.
    To be clear its the window itself, not dirt/streaks etc.
    Anyone else have this? Anyone point it out to a dealership, and whatd they say?
  2. May 11, 2024 at 6:42 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If you are wearing polarized sun glasses it’s polarization that you are seeing take your sunglasses off and it will go away.
    The polarization spots in the glass when combined with the polarized filter of your lenses essentially cancel out the light that is coming through and creates the effect of “dark stripes“
    Chew and TheWildMan[OP] like this.
  3. May 11, 2024 at 7:04 PM
    TheWildMan
    This is an excellent point, and I did think of that. Depending on conditions they can be way more pronounced when wearing sunglasses. They are still visible without sunglasses in certain conditions, or if your just really looking for them. I do believe its the sun film in the glass, thing is its only the driver window that sticks out/ is different.
  4. May 11, 2024 at 7:24 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    one thing i am not going to do is go look to see if my windshield has them. once i would see them i will never be able to unsee them!
    t0p_d0g and TheWildMan[OP] like this.
  5. May 11, 2024 at 7:29 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Is it a visibility issue inside the truck?
    TheWildMan[OP] likes this.
  6. May 11, 2024 at 7:41 PM
    TheWildMan
    Gotcha.
    Gonna try to think of why it would be one!
    Idk man, its just shitty. But Im assuming thats the criteria and the dealership will tell me to walk?
  7. May 11, 2024 at 8:15 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I think there's a new crash safety requirement for cars to use laminated glass for the front side windows. Roll down the window and see if the edge looks like two pieces of glass glued together, or one solid piece.
    Edit: my 2019 SR has normal (not laminated) glass. I didn't see any lines, but I haven't looked with sunglasses yet.
  8. May 12, 2024 at 10:41 AM
    TheWildMan
    The bevel is almost frosted, but I do believe its a uv sheet pressed in between the glass. When Im in a well lit place at night I can sometimes see it reflecting light kinda like a disco ball lol. Have to be at the right angle (looking from near front wheel well mirror area). Its kind of like if you had several strips of mirror and pushed them together but they werent all flush/level with each other.
  9. May 12, 2024 at 12:44 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Is it possible the window has been replaced with aftermarket glass? This might explain why the one window is different. Check the window labels.
  10. May 12, 2024 at 1:11 PM
    TheWildMan
    Damn good call Ill check
  11. May 12, 2024 at 1:22 PM
    TheWildMan
    Glass is the same. Both say Pilkington. I know pilkington makes glass for various companies, though I am surprised they'd actually be marked TOYOTA Pilkington instead of just toyota. They have the same designations/codes, but they dont have the vin on them.
    Toycoma2021 likes this.
