link to pinch weld mod
Discussion in '1st Gen. Builds (1995-2004)' started by tacoma matt, Mar 1, 2010.
  1. Mar 1, 2010 at 5:17 PM
    tacoma matt
    tacoma matt [OP] Member
    South Jersey
    95 Standard cab 4x4, Ultimate lift kit
    k&n, deckplate, throttle body spacer, Toytec ult. lift kit, cust. bumpers front and rear, cust exaust.
    any1 have a link to the pinch weld mod?
  2. Mar 1, 2010 at 5:32 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
  3. Mar 3, 2010 at 2:02 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    and if your going realy big just cut it out and weld in a plate of steel on both sides at an angle !
    G59 likes this.
  4. Mar 3, 2010 at 12:01 PM
    4x4Tacoma
    4x4Tacoma Well-Known Member
    Ben
    Fresno, ca.
    08' Tacoma, RR lock 295/75/16 MT 3" level kit
    3" leveling kit by Hell Bent Steel, 295/75/16R mud tires
    So hammering te weld over is okay has anyone done this and if so is everthing still good?
  5. Mar 3, 2010 at 1:38 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    you can either hammer it over which is fine, but it can be a spot for water and mud to sit and cause rust, or take a few more minutes and grind it nice and smooth then hit it with some paint.
  6. Mar 3, 2010 at 1:46 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    i would rather bend it than grind it off. that seems like a bad idea to weaken the spot where your tire is most likely to slam into
  7. Mar 3, 2010 at 2:26 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    to each his own
