List of compatible/swappable rims?
Discussion in 'Wheels & Tires' started by bobmcduff, Oct 15, 2024.
  1. Oct 15, 2024 at 7:31 PM
    bobmcduff
    bobmcduff [OP] Well-Known Member
    South Jersey, USA
    2022 DCSB TRD Sport in MGM
    Okay, trying to think of the best way for phrasing this, but essentially what I am looking for is a list of all the factory model rims that would ultimately be equal to the stock '22 TRD Sport combo that came on the truck. So in my case I have 265/65 -R17's on 17x7.5 rims with I believe a +30 offset. Want to keep the same overall diameter and width of tire, but looking to pick up a set of rims to run an A/T or winter tire setup. I believe the TRD Off Roads 265/70R16 w/ 16x7 +25mm rims would essentially fit in that scenario, but curious how many other Taco/4Runner/FJ Cruiser combos would be essentially a direct match up or close enough to not notice (how far before the offset changes that you start to notice handling changes or get rubbing).
    Kicking myself for not grabbing a set of FJ Cruiser rims from a co-worker before the company downsized.
  2. Oct 15, 2024 at 7:43 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You can usually find Sport takeoffs for cheap, if you keep your ear to the ground. Nobody wants them, and people get rid of them frequently.
    Otherwise, you can go up to a 0 offset without much penalty. I personally went with the 4Runner SEMA wheels, a highly popular yet not terribly expensive option. (17×8, +4 offset) If you want cooler wheels, look at those.
    boston23 and bobmcduff[OP] like this.
  3. Oct 15, 2024 at 7:58 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    When you get into negative offsets (-10, -32 ect.) is where you increase your chances of rubbing on cab mount, fender liner ect. A few manufacturers offer a 0 offset. As far as cross compatibility from different models, hub bore of 106.1 mm and bolt pattern of 6x139.7/ 6x5.5.
    Also correct me if I’m wrong, but TRD Sport wheels and SEMA wheels are both only 7” wide
    bobmcduff[OP] likes this.
  4. Oct 15, 2024 at 8:00 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    You're close. 3rd gen sport wheels are 7.5", SEMAs are 7.0"
    TacoJoeBro[QUOTED] likes this.
  5. Oct 15, 2024 at 8:03 PM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    :hattip:
    Rock Lobster[QUOTED] likes this.
  6. Oct 15, 2024 at 8:14 PM
    eurowner
    eurowner Duke Sky
    Scoty
  7. Oct 16, 2024 at 12:29 PM
    bobmcduff
    South Jersey, USA
    Nice, that's the kind of list I was looking for, now to try and dig up the same for 4Runners and FJs, and keep my eyes open (I'm cheap, and to be honest don't like all of the options, but like a handful)
  8. Oct 16, 2024 at 2:04 PM
    eurowner
    eurowner Duke Sky
    Scoty
